Cut bars.
3 replies to this topic
  • FOX426
Posted January 14, 2004 - 01:06 PM
I usally cut my bars for the woods around 29 or 30 in. I have not used cut down PRO TAPERS before. What length do you cut them to for woods and is there anything different I should do to the pro tapers? BTW they are kx hi bend and 32in wide.
  • RunAnywhere
Posted January 14, 2004 - 04:25 PM
I cut mine down to 30.5. I just used a pipe cutter. The kind like a c clamp with a cutting wheel. Then I deburred it and sanded the little bulge the cutter made.
No problems.
  • FOX426
Posted January 15, 2004 - 02:13 PM
Does cutting the pro tapers throw off your handguard mounting?
  • tctrailrider
Posted January 15, 2004 - 02:52 PM
Yes but easy to fix. Cut the handguard shorter and drill a new hole.
