What oil do you run?
50 replies to this topic
  • wizbangdoodle
Posted March 25, 2014 - 09:18 PM
Just curious as to what oil you run in your WR.  I'm using a semi syn now and it seems to work fine.  Just wondering if there is anything I am missing.
  • Krannie McKranface
Posted March 26, 2014 - 05:40 AM
As long as you run Motorcycle oil that is rated JASCO MA, you are not missing anything.
  • DuncR6
Posted March 26, 2014 - 09:38 AM
Amsoil.
  • flyandride
Posted March 26, 2014 - 10:41 AM
Rotella T6
Posted March 26, 2014 - 01:30 PM
JASO.  Either MA or MA2.  Never MB.
'Wish that were true, but it isn't as often as it should be.  Getting better, though.
  • RMK800
Posted March 26, 2014 - 07:08 PM
Rotella T6 21.50 full Synthetic at Walmart. Plus there is a 5.00 rebate until the end of April. 16.00 is a great deal for full synthetic JSO certified.
  • mrgem
Posted March 28, 2014 - 04:55 PM
Rotella T6
Ditto on the Shell Rotella Full Syn.
  • 67imp
Posted April 01, 2014 - 04:30 PM
rotella as well.
  • wizbangdoodle
Posted April 01, 2014 - 05:48 PM
Wow, I had no idea Rotella was so popular.  Any particular reason Rotella is everyones oil of choice?
  • RMK800
Posted April 01, 2014 - 07:12 PM
Three reasons.... JASO certified, full synthetic, and cheap. IMO you can't buy a better oil for the price. I put it in EVERYTHING from Dirtbikes, lawn mower, snow blower and of course my Diesel.
  • mrgem
Posted April 01, 2014 - 07:32 PM
As RMK said, at 5 bucks and change a quart, it is substantially less expensive than those oils touted as being uniquely suited for the specific rigors that go with motorcycle operation. And it meets or exceeds the JASO-MA standards (although Shell hasn't applied for JASO certification - as far as I know). It is by all accounts, the highest-quality oil you can buy at less than 22 bucks a gallon. This makes a difference if you like to change your oil frequently.
Read this for some of the technical details:
http://motorcycleinf....com/Oils1.html
  • Elkjunkie
Posted April 05, 2014 - 12:34 AM
So I shouldn't use my mobile delvac 15w-40. I got a few gallons for free but it doesn't say jaso. Good thing I have a diesel lawnmower. I'll be another rotella guy next change.
  • YHGEORGE
Posted April 05, 2014 - 02:58 PM
I wouldn't hesitate to use the Delvac. Or Chevron Delo, both great oils. Much ado about nothing!
  • funt
Posted April 05, 2014 - 05:07 PM
Synthetics are too slippery for the clutch if they're not rated for it.  Conventional oil won't kill the clutch.  I would avoid synthetic blends to be on the safe side.  I use rotella T6
Edited by funt, April 05, 2014 - 05:08 PM.
  • mrgem
Posted April 05, 2014 - 07:52 PM
In my experience, the clutch plates in a wet clutch do not care if an oil is dino or synthetic or a partial synthetic. What they do care about is whether the oil contains friction modifies like molybdenum. They blends are typically only 15% synthetic, anyway, which doesn't justify their higher price.
You can usually tell an oil with a bunch of friction modifier by a round stamp on the lable that says "Energy Conserving." Most 10w30 oil has this stamp as well as some other oils.   I've run Rotella T6 (as you pointed out -- a full synthetic) in all my road and trail bikes for many years. I agree with you that T6 is a superior oil. Wouldn't use anything else.
It actually helped the clutch on an old KLR Kawasaki I used to own. Using Kawasaki oil (K-Tech 4 Stroke), the plates would sometimes stick. I switched to Rotella and the  problem was solved.
  • Trixster8
Posted April 06, 2014 - 06:11 AM
Do you guys think it's safe to break in a big bore kit with T6? I came across an article that said not to use synthetic oil for engine break in. Just wanted some other opinions.
  • Nuklhed
Posted August 22, 2014 - 02:57 PM
I'm considering switching to this stuff just because I have a bunch of it.  Any issues, like clutch slippage I should worry about?  I ran it in my KTM 525 with no worries--other than it getting filthy at 150 miles...like clockwork.
By the way, Amazon says, "Exceeds API SL and JASO MA-2."
  • underground-mpyre
Posted August 23, 2014 - 03:44 AM
Also a big fan of Rotella T6. I put that sh!t in everything. I have been instructed to change my oil every 300 miles(of course only an estimation) and Rotella is a cheap and durable way to go.
  • guru
Posted August 23, 2014 - 08:52 AM
I have been told no syn for break in as it won't let rings seat properly.
  • Nuklhed
Posted August 24, 2014 - 07:55 AM
I'm past break-in.  At nearly 200 miles on the odo.  First oil change was about 25 miles.  This'll be number 2.
