2010 yz450f no oil in the clutch
4 replies to this topic
  • moeyz250
Posted March 24, 2014 - 09:37 PM
I just bought the yz450f last week I changed the oil and put a rekluse exp 2.0 in it and the clutch whent out. When I put the exp 2.o in I had noticed that that the clutch plates were not wet like they should be I thought maybe that since the clutch plates were new that they hadn't lubed up yet. the previous owner said he changed the plates they are etc clutch pack I'm use to 2 strokes this my first 4 stroke. I'm not sure if something is clogged so the oil can't transfer from the motor side to the clutch side any help would be greatly appreciated.
Posted March 25, 2014 - 06:41 AM
Assuming it's not a '14 model, the YZ450 is a dry sump system.  The clutch and trans don't run in a "pool" of oil like a two-stroke gearbox, but are pressure fed from the oil pump, and everything that drains to the bottom is scavenged up and returned to the feed oil reservoir.
The clutch receives oil from the center of the main shaft, past the clutch push rods.  It isn't as much as most people expect to see, normally, either, so your comment is pretty typical.  I wouldn't worry about it.
  • moeyz250
Posted March 25, 2014 - 09:11 AM
How much oil should come thru the main shaft. The clutch was fried when we pulled it out I haven't had the time to take the rekluse apart to see if it's ruined or not.
Posted March 25, 2014 - 09:24 AM
Not a great deal.  The plates usually have the appearance of being fairly dry.
If you want, you can verify oil delivery to the clutch by running it with the clutch opened.  Do this only if the right side crankcase cover is still in place with the clutch cover off, and beware of moving parts when it starts up.  You will also want to protect yourself and the immediate area from oil slinging off of the assembly.
Remove the pressure plate and all of the clutch plates, and also remove both clutch push rods and the ball in between them.  Note that you may need someone to hold the clutch release arm down in order to prevent oil pressure from pushing it up out of the bore.  This may not happen with the clutch opened up, but it could.   When the engine runs, there should be a significant amount of oil that will be discharged from the shaft bore.
In operation, that is not the oil actually delivered to the clutch.  The Clutch end of the long inner push rod meters the oil to the clutch by having it flow around an enlarged area that has spiral cut grooves in it for that purpose.  Looking  at these, you can see that the oil that is intended to get to the clutch is intentionally not a lot.
  • moeyz250
Posted March 25, 2014 - 09:29 AM
Thanks you have been a big help
  • Hot  36 replies
  • Hot  47 replies
  • Hot  30 replies
