Hotcams on XR 650L
4 replies to this topic
  • atreiou
Posted January 14, 2004 - 06:27 AM
anyone have experience in using an hotcams cam on the XR 650L with electric start only ?
there are problems for the start of the engine ?
I remeber to you that the installation of the hotcams need the elimination of the automatic decompressor, and the manual decompressor is not available on this bike..
thanks to all..
  • HotCams
Posted January 14, 2004 - 08:25 AM
If you have the stock compression piston, you shouldnt have a problem starting it for two reasons. One, on our camshaft, the intake valve is open late enough on the compression stroke, that it bleeds compression at cranking speeds, and two, that motor only has around 8.3:1 compression ratio stock. I hope that helps, let me know if you have any other questions.
Sean
  • atreiou
Posted January 14, 2004 - 10:09 AM
thanks for the fast response.
  • HotCams
Posted January 14, 2004 - 11:02 AM
No problem :)
  • mountainrider
Posted December 18, 2004 - 07:57 PM
What happens if you go with a high compression piston?
Fell Off Trailer by usafxr
  • Hot  43 replies
Would a Young Scott Summers still be Competitive today on an XR600R? What would he ride to be competitive today? by Jayzonk
  • Hot  159 replies
  • 22 replies
  • 9 replies
  • Hot  60 replies
