FMF powercore 4 and powerbomb question
13 replies to this topic
  • Romper290
Posted March 23, 2014 - 11:46 AM
Im thinking about ordering a fmf powercore 4 slip on and getting a powerbomb exhaust was curious on knowing if it is gonna be pretty loud and on the power output
  • William1
Posted March 23, 2014 - 12:08 PM
Louder than what?
Most after market pipes either shift the power 'sweet spot' or in the cases of severely restricted (and super quiet) bikes, add more top end as well.
LOL, 'generally speaking' there is no blanket statement that can be made unless specifics about your bike are made. Add to that the kind of riding you do will enable those with experience to better guide you.
  • 95jersey
Posted March 23, 2014 - 04:05 PM
Powercore 4 is loud.  I have this combo and it makes great power, I would not hesitate to buy again.  I have yet to see if it passes the 96db sound limit.  It does come with a spark arrestor that quiets it down significantly.
  • The Spanky
Posted March 23, 2014 - 04:32 PM
Almost all aftermarket exhausts come with inserts that will bring the decibels down to the 96dB limit. But without the inserts the sound output is all over the place, some aren't any louder than stock and some are ear-splittingly obnoxious.
FMF systems tend to be quieter than most, but without the inserts they are typically louder than OEM, with the exception of Kawasaki. Kawasaki's OEM exhausts are obnoxious.
  • JulianMotovlog
Posted March 24, 2014 - 04:27 PM
I love my powercore 4, it has a deep and loud bellow. It sounds smooth and clean but I don't bother with the quiet insert, just the spark arrestor. I found no change in volume with just the spark arrestor in. It added power to almost the whole rev range. I recommend it, it's a solid and well built pipe, and it's a noisy one!
  • Romper290
Posted March 24, 2014 - 04:42 PM
Now I got a yz426f its a 01 if I get the powerbomb for it will there be a noticable change in low range power
  • tang426
Posted March 24, 2014 - 04:48 PM
I put one on my 02 426. Too loud. More flame outs and no more power stock is the best for that bike. I'll sell you the powercore if u like. It's collecting dust
  • Romper290
Posted April 09, 2014 - 07:07 PM
Okay finally got the whole exhaust system for my 01 yz426f. Major power gain top and bottom end. But getting off subject would my bike make a tapping noise if the valves needed to be adjusted or could it be that it needs a oil change
  • C4pt. 5p4uld1ng
Posted April 09, 2014 - 07:48 PM
Definitely don't ride it. Could be the valves.. Could be the time adjusting chain is loose. Get it looked at!
In my past experiences.. Flames= need for valve adjustments.
  • Moto rookie
Posted April 10, 2014 - 02:12 AM
Flames = extra cool points.
  • Romper290
Posted April 10, 2014 - 02:27 AM
I work on bikes myself never again will include take a bike to a shop but I never ran into this problem before is it a easy fix yourself
  • Romper290
Posted April 10, 2014 - 06:01 PM
Does anyone know how much oil a 2001 yz426f takes it says 1.6 liters but when i changed the oil it took only 1 court witch is only like .986 liters
Posted April 10, 2014 - 07:02 PM
Read:  http://www.thumperta...odel-400s-426s/
  • Romper290
Posted April 10, 2014 - 07:21 PM
Now what about the ticking noise and that answer was very useful looks like im gonna half to change oil again completly forgot about the other bolt on the frame for the oil
  • Hot  113 replies
  • Hot  38 replies
  • Hot  30 replies
  • Hot  36 replies
