Help 1999 wr400f breaking up 1/4-3/4 throttle
6 replies to this topic
  • Glocklife
Posted March 21, 2014 - 03:40 PM
I just bought a street legal 1999 wr400f it has the gray mod, air lid off, full exhaust with a big gun pipe, I dont know what jets are in it. The bike runs greats expect between 1/4-3/4 throttle. So I read and read and found out about the TPS I look at the bike and it's already disconnected so I connect it.... NO difference. So I dont know what to do any advice?
  • flyandride
Posted March 21, 2014 - 03:47 PM
1/4 to 3/4 would be controlled by the position of the needle.  You should be able to loosen the carb and rotate it so you can get to the top of the carb.  Pull the slider and needle out and raise or lower the clip on the needle.  See which way improves it.  While you're at it you should pull off the float bowl, pull the jets and clean them.
  • Krannie McKranface
Posted March 21, 2014 - 05:17 PM
Yes, but HOW does it run in the 'bad' throttle range: gurggly, or kill-button-y, or on-off-y....
Edited by TheKoolAidMadeMeSick, March 21, 2014 - 05:17 PM.
  • Glocklife
Posted March 22, 2014 - 08:13 PM
Ok thank you for the advice on the needle it was on the 3rd notch of the factory needle I moved it down 3 spots to richen it and it got worse so I raised it to the top and it really really well now but still a little hiccup here and there at a sustained throttle between 1/4 and 3/4. I also found out I have a 38 pilot jet and a 160 main jet.
  • Glocklife
Posted March 22, 2014 - 08:15 PM
It was running on-offish like spark! Then no spark!
Posted March 23, 2014 - 06:15 AM
A 38 pilot is too small. 42 or 45
160 main is fine, but small, like for high altitiude or really wet air
The most common problem with older carbs is the needle jet wearing out: it ovalizes, and you end up chasing jetting issues to insanity.
You should go to the 400/426/450 FAQ and see what others use for jetting, and replace your needle jet (not jet needle), apump diaphragm, pilot, and adjust your valves.
  • Glocklife
Posted March 25, 2014 - 07:33 AM
Thank you guys
