08 yz450 only 4 gears?
Yamaha YZ450F
47 replies to this topic
  • dirtjunkie23
Posted March 20, 2014 - 05:47 PM
Never owned a yz450 before.this is my 1st one. Anyway this thing is pretty nice. I bought it for 1700 bucks from a friend of a friend. Starts first kick every time. But when i bought it the guy told me it was a 4 speed. I took it for a ride and sure enough only 4 gears. Still works great though. But when i looked up the specs on an 08 it says they are five speeds. Was 4 speeds an option or what? Not sure why its only got 4 gears. I hope 5th gears not broken or something. But it doesnt act like there is another gear, it just stops shifting like thats all the gears there is. Sorry for the dumb question. But can somebody help me out.
  • lkeffersyz
Posted March 20, 2014 - 06:05 PM
Well you could order a transmission kit and put it in.... or someone paid a good bit extra to have it with a 4 speed from factory. Check the rest of the engine and trans out if you are ever bored it may have some more goodies on it
  • Calebxmaxx
Posted March 20, 2014 - 06:08 PM
Are you sure it's a 2008 and not an 03-05? Possible they told you the wrong year. The 2003-2005 came from the factory with only 4 gears. If it has a blue steel frame that's what you have.
  • lkeffersyz
Posted March 20, 2014 - 06:11 PM
Yeah it could be that too I bought an "03" yz 125 onetime and it turned out to be a 01 only difference on them was intakes are different. I tried to order a new one and it wouldn't fit so I ordered another and sane thing. Look at the frame the 4th two digits are your year. I solved my problem with that
  • dirtjunkie23
Posted March 20, 2014 - 09:42 PM
No it has the aluminum frame. And i looked on the frame for the number and the number is jyacj10c38a027446 so im not sure how to tell what year it is by that number
  • writebrian
Posted March 20, 2014 - 10:32 PM
If it's aluminum frame it is definitely a 5 speed from the factory.
  • dirtjunkie23
Posted March 20, 2014 - 10:47 PM
Well then why would it only have 4 gears. If 5th gear was broken i would know it right. Would it still try to go in 5th gear but just not work? Cuz when i try to go to 5th it just wont. It acts like it only has 4 gears. Hell i dont know. Is it possible that some body put an 05 engine in a 08 frame or would it not fit?
  • dirtjunkie23
Posted March 20, 2014 - 10:49 PM
Dont get me wrong the thing kicks fricken butt. I dont really need 5th gear. But im just concerned something might be messed up
Posted March 21, 2014 - 05:43 AM
Looking at the right side of the engine, is there an external steel oil line with 3 branches with one running up to the cylinder head?
  • 2smoke4stroke
Posted March 21, 2014 - 08:57 AM
Is there a possibility the engine has a 4 speed transmission dropped in? Maybe something for the dessert for wider ratio riding?
  • x_JT_x
Posted March 21, 2014 - 09:01 AM
How about a couple pictures? This could speed the process of figuring out what's up up greatly.
Posted March 21, 2014 - 09:43 AM
That's cute. What's the part number on that?
The 4 speed from an '03-'05 YZ450 will not bolt into an '08, and the 4 speed isn't a wide ratio box. The first 3 gears are the same in the 4 and 5 speed YZ450's, and the ratio of the 4 spd 4th gear is in between that of the 4th and 5th on the 5 speed.
What IS possible is to bolt in (more or less) the complete engine from an '03-'05, which is why I asked the question about the external oil line.
  • nucular
Posted March 21, 2014 - 10:52 AM
Does the engine # match the frame?
Posted March 21, 2014 - 11:10 AM
No. They never do.
  • nucular
Posted March 21, 2014 - 11:28 AM
No. They never do.
How about this - does the year code on the engine # match the year code on the frame?
  • dirtjunkie23
Posted March 21, 2014 - 11:29 AM
no there is no steel line
  • dirtjunkie23
Posted March 21, 2014 - 11:33 AM
Heres some pics. Sorry i was checking my valves
Posted March 21, 2014 - 12:04 PM
That's definitely a Gen2 engine, and should be a 5 speed.  Sounds like exploratory surgery is in order.
  • dirtjunkie23
Posted March 21, 2014 - 12:10 PM
well is it possible that someone made it a 4 speed? And how would i tell without splitting the cases. Im not good with bottom end work.if 5th gear was broken wouldnt it still try to shift into 5th. Cuz like i said after 4th it just feels like theres no more gears.
  • schrode
Posted March 21, 2014 - 12:13 PM
so the frame is definitely an '08. i looked that number up and confirmed it.  what's the likelihood somebody grenaded the motor and put an earlier year in?  that's what i'm leaning towards as an explanation.
  • Hot  113 replies
Motocross
  • Hot  491 replies
  • Hot  50 replies
