Starting a '13 with a dead battery
7 replies to this topic
  • 41racing
Posted March 19, 2014 - 07:22 PM
Just wondering if my 13 wr 450f will start with the kicker if the battery is dead? Not dead like it isn't enough to turn it over I mean dead like I left the switch on or the battery is removed.
  • William1
Posted March 20, 2014 - 02:54 AM
You need a battery installed and it cannot be completely flat. At least 11 volts or so and a good battery (meaning it woud take a charge).
  • WRLuisSa
Posted March 20, 2014 - 04:31 AM
It will start with no problems with the kickstart even if the battery is completely flat. Had this issue before on my 13'.
However, with the bike running for a while it will not be enough to charge the battery. You need to remove the battery and use a battery charger
  • avlisj
Posted March 20, 2014 - 06:53 AM
Should be able to start with even without the batt
I was told that about two or three slow kicks charges a stator( or something like that) and then your ready to go
Haven't physically tried it myself
  • Krannie McKranface
Posted March 20, 2014 - 04:34 PM
If the battery is dead (as in no battery) it will not start by kicking, because you an open circuit.
If you have any conductance at all (as in a battery that will not spin the starter), you can kick it.
  • funt
Posted March 20, 2014 - 04:45 PM
I was able to start mine with a blown main fuse.  I think there's a couple circuits that go around the fuse though.
  • woods-rider
Posted March 21, 2014 - 11:22 AM
The '12+ WR450s have a capacitor so that you can remove the battery completely and kick it, so it will start just fine with a dead battery or no battery at all.
Posted March 21, 2014 - 01:04 PM
Yes, the FI's can do that, you are right.
Edited by TheKoolAidMadeMeSick, March 21, 2014 - 01:05 PM.
