FMF slip on
Brand FMF Racing
6 replies to this topic
  • avlisj
Posted March 16, 2014 - 04:28 PM
I got a 2014 wr450. Did the free mods and the bike rips enough for me as it is but would like the q4 muffler
Will this make me have to get the comp ecu and tweek the settings to keep it running crisp.
I know that running without the whole tailpipe assembly in the stock muffler makes it pop more and not idle as good.
Do the 2014s need the CO adjustments also (ie is it set at 0 also from factory)
  • guru
Posted March 16, 2014 - 10:29 PM
Just back from two days on the 2013 WR450F. Put a powercore pipe and comp ecu. Programmed with map that came with the pipe. F'ing fantastic. Only 80 miles on the bike I'm already in love. ImageUploadedByThumper Talk1395037595.194194.jpg get the pipe ecu and beg borrow steal a powercommander.
  • avlisj
Posted March 17, 2014 - 06:51 AM
Just back from two days on the 2013 WR450F. Put a powercore pipe and comp ecu. Programmed with map that came with the pipe. F'ing fantastic. Only 80 miles on the bike I'm already in love. attachicon.gifImageUploadedByThumper Talk1395037595.194194.jpg get the pipe ecu and beg borrow steal a powercommander.
Yea. Looks like Mendocino NF. What did the CPU and pipe do to your range(mph). How far did that 2 gal take you?
  • guru
Posted March 17, 2014 - 10:09 AM
El Dorado NF The gas light was on at under40 miles! I have the 3 gal IMS to install.
  • avlisj
Posted March 17, 2014 - 04:10 PM
Nice
I've done bear river res to the backside of kirkwood a couple times
Sweet trails. Georgetown and foresthhill
Too bad you got put that fat tank on that thin frame
I like how light the bike feels
Specially coming from a rm250 probably 50 lbs lighter
  • guru
Posted April 03, 2014 - 08:49 AM
Fat tank and 47 tooth rear make the girl fun in the desert. I'll post range when I use a full tank. Really still loving the powercore. Not too loud until you really get on it.
Going from an XR650R this bike is light, fast and all around dreamy.
  • revxp_800r
Posted April 03, 2014 - 12:57 PM
When I put Yoshimura rs4s on mine I had to do ecu. Bike wouldn't run without it
