04 yz450f help me get trail ready
21 replies to this topic
  • joey330
Posted March 14, 2014 - 04:03 PM
Bike is awesome fast touchy. I do not want a flywheel weight as I love the low end torque love riding one wheel and monster hillclimbs. I mostly ride Hatfield mccoy I am experienced track and hill climbs. New to the undergrowth wet muddy trail rides.
I have bark busters so far. Got new tires for trail.
What are some good things to know about this year bike? I have new chain and sprockets.
what can I buy to save me a lot of trouble with my bike? Off topic. What are issues with this year model? I'm dropping my bike off as I am working 100 hour weeks for the next two weeks and need it trail ready when I get off to ride the same day. Fast response much aprreciated.
  • Will.A.R.
Posted March 14, 2014 - 05:14 PM
Ive got an 04. For the woods i dropped one tooth on the front sprocket and have a FWW. Dont be fooled, that weight helps tremendously as far as stalls but my bike still hits harder than several other newer 450s on my mx track. on the track I add that tooth back to the front but the stealthy remains. No complaints here and i'm not light weight feller. I also have a set of narrow bars and bark busters for trail use.
  • FRANTIK1
Posted March 14, 2014 - 06:44 PM
Skid plate for sure. I would consider a bigger fuel tank in time. Lower  gearing helps a lot but is open to personal preference.
FWW is for sure the best thing I did to my 09. I have not had a flameout since I installed it 2 seasons ago. It only adds to offroad performance. Takes nothing away.
  • joey330
Posted March 14, 2014 - 11:42 PM
The stalls are unbelievable yes and my foot could use a break. Harder then heck to start after to. What is the reason for the common Unpredictable stalls? I'm getting the Clarke 2.6 gallon tank installed this week. Hare going 5 miles to just ride one double black to ride back to fill my tank kinda kills it
  • joey330
Posted March 14, 2014 - 11:45 PM
What kinda of skid plate? What about crash bars like a street bike to protect my case from drops and falls? Oversized radiatoe? Or does bike stay pretty cool? Rad gaurds? Those important or stock fine? 8 not made of money so wanna go semi slow but be well prepared for my hill climb comp in two weeks then my hard trail riding after
  • FRANTIK1
Posted March 15, 2014 - 07:37 AM
Radiator guards. Yeah. forgot about them. I have yet to put them on mine . I want them for this season.
 I have a GYTR skidplate on mine, and if I did it over again, I would have got a Ricochet or Devol. Ricochet is thicker, and I think covers a little more, and is a lot cheaper than my GYTR. I get most stuff like skidplates, handguards, etc fom ebay. Skidplate on my aluminum frame goes on and off easy.  Steel frame skidplate uses clamps..... you might be making up a lotta new words putting it on. But I would not ride tough trail without one. Think of it as handguards for your engine cases.
  • FRANTIK1
Posted March 15, 2014 - 07:47 AM
Also forgot about a TM designs or similar chain guide. Stock are steel caged and bend easy from rocks. when I replaced my chain and sprockets I bought a stock steel chain guide and it was bent from rocks instantly. Never again.
  • FRANTIK1
Posted March 15, 2014 - 07:51 AM
Lack of flywheel inertia on a highly tuned, high RPM design engine.
  • joey330
Posted March 15, 2014 - 08:42 AM
Frank I will be getting the steel one depending on price. I can't afford a cracked case
  • riderdietryin85
Posted March 16, 2014 - 03:01 AM
I ride a 03 in the woods .. best investment to date hand guards lol.. I was over heatin a bit in the slow clutchy stough so i did oversized rads and high flow water pump .. also might wana make a catch can for the large vent tube i used a rubbing alcohol bottle and some old air filter foam.. best of luck .. ps i dont wana mess up my bikes snap either so no fww lol
  • rmunch44
Posted March 19, 2014 - 12:39 PM
Rekluse Exp 3.0 and Engine Ice
  • joey330
Posted March 19, 2014 - 04:08 PM
What does the Rekluse do? I can use engine ice in place of oversized rad and water pump?
Edited by joey330, March 19, 2014 - 04:13 PM.
  • joey330
Posted March 19, 2014 - 04:15 PM
So far I have skid plate bark busters. Few other things as well. What else?!? Thank you everyone
  • rmunch44
Posted March 19, 2014 - 04:34 PM
Check out the Rekluse website for full details, but no more using the clutch unless you want to and it doesn't stall when you fall over.
Engine ice is a coolant that keeps the temps lower than regular coolant. I noticed that I was overheating on tight single track until I switched to engine ice.
  • joey330
Posted March 20, 2014 - 04:21 PM
Rekluse is a no go. Sounds nice but I am a bit more technical then that. Pretty much cheating I in my opinion.
Engine ice is a go. Anything else?
  • yammiehall
Posted March 21, 2014 - 11:49 AM
I have an 03 it's an amazing bike no issues what helps for me is besides a flywheel weight is a Hinson weighted clutch basket and one lower tooth on front. I have never even touched the valves and i race enduro so it is ran hard and never had an issue i do recommend radiator guards also stock radiators are very weak hope this helps
  • rmunch44
Posted March 24, 2014 - 10:12 AM
I agree on the radiator guards for sure. I have Unibiker radiator guards and highly recommend them. Check out the price on new radiators and you'll see what a little money now will save you a bunch later.
  • Hoosier-Daddy
Posted March 24, 2014 - 05:45 PM
Engine ice, handguards, heavy flywheel, and 13/51 sprockets. Getting the right spring rates on shock and forks and setting sag too. Rides like a totally different bike.
  • riderdietryin85
Posted March 28, 2014 - 06:48 AM
I just got mine ready for the summer .. so cant wait
  • yammiehall
Posted March 29, 2014 - 06:43 PM
how do you like that pewer bomb header?
Sent from my iPhone using Thumper Talk
  • Hot  113 replies
  • Hot  30 replies
  • Hot  47 replies
  • 3 replies
  • On January 15, 2017
