Uncorking wr450f
10 replies to this topic
  • Adamridesorange
Posted March 11, 2014 - 03:29 PM
I'm looking at buying a wr450f. I've been reading that stock they are kind of a dog are are really restricted for reliability and emissions reasons. If I get one I'm thinking of doing all the mods such as the grey wire mod, throttle stop, jetting, pipe, ect. How much does this increase performance, as I want a 450 to act like a real 450 and not an xr 250? And being as restricted as they are I've heard it helps with reliability...if it's uncorked and putting upwards of 45-50 hp, would it shorten the life span of the piston and rings? Just curious.
Thanks.
  • Krannie McKranface
Posted March 11, 2014 - 04:29 PM
1,689,725,235 posts on this subject already.
  • OUTERLIMITS
Posted March 11, 2014 - 04:43 PM
Thanks.
Assuming you are talking about a pre '12 bike as the fuel injected bikes are even easier to uncork.  I have an '08 in the garage that I'm selling, after replacing it with a '12.  Once uncorked, jetted, grey wire, de-smogged, throttle stop removed, and a proper slip on, the bike became an absolute animal and does not disappoint.
  • Adamridesorange
Posted March 11, 2014 - 05:07 PM
Does doing this shorten the piston and ring life by a little bit as it's putting out a lot more power?
Thanks.
Posted March 11, 2014 - 06:56 PM
Thanks.
Modding a motor will not wear it out.
Using and abusing it will, stock or modded.
It's not an issue.
  • stevethe
Posted March 11, 2014 - 08:34 PM
Thanks.
Yes almost 50 reliable Hp at the rear wheel. But your going to have to buy one and ride it !
  • flyandride
Posted March 12, 2014 - 01:12 AM
Thrashing it will shorten the life of the engine as will lack of maintenance.  You'll want to do the free mods otherwise you might get blown away by someone on a clapped out 125.
  • Adamridesorange
Posted March 12, 2014 - 02:42 AM
Does anyone know the stock hp the wr is putting out?
  • jimmym
Posted March 12, 2014 - 03:45 AM
19 hp, according to the following article: http://motorcyclejaz...maha_WR450F.htm
  • Adamridesorange
Posted March 12, 2014 - 04:31 AM
I've read that article and that seems awfully low for a 450, but that's probably why they are so reliable..I'd think if they are pushing 50hp with mods, that it would Atleast affect reliability a little bit..
  • JokerWR
Posted March 16, 2014 - 07:07 AM
I have recently acquired an 08 I was disappointed at first but had to wait a while till I put some more time on it as the PO only rode it a few times and it had less than 200 miles on it and I figured I should break it in a little more before opening it up. Yesterday was my first ride after doing so and I can not believe how much better the bike not only runs but rides. It feels lighter and Soooooooooo much peppier do to the power. Here is what I did.
1. Applied AIS removal kit.
2. Grey wire.
3. JD Jet Kit.
4. RD fuel screw.
4. O - ring mod.
5. Removed air snorkel.
6. Pro - circuit full system.
Honestly it not only runs but rides like a complete different bike.
