compression issue
6 replies to this topic
  • 67imp
Posted March 10, 2014 - 03:39 PM
2002 wr426 , something is a wrong, I can turn over the motor without using the decompression lever. what is the chance that it is a stuck valve and if so solutions?
  • Krannie McKranface
Posted March 10, 2014 - 05:18 PM
It's one of:
Stuck valve
Leaky valve seat
Broken decomp << most likely
  • 67imp
Posted March 10, 2014 - 05:41 PM
how does one tell if the decomp is broken? I am able to pull in the lever and see the switch move under tension.
  • flyandride
Posted March 10, 2014 - 07:02 PM
At least one of the valves has zeroed out.  Meaning no clearance and loss of compression.  Time for a head rebuild.
Posted March 10, 2014 - 08:00 PM
Actually, a zeroing valve usually does not mean no compression, just no start.
Posted March 11, 2014 - 01:30 PM
A valve at zero generally does cause a loss of compression.  Usually, by the time they get in that condition, they go beyond zero, and you find them off the seat when the engine cools down.
Posted March 11, 2014 - 04:31 PM
You are right
