2014 YZ450 Exhaust pipe glowing red at idle?
19 replies to this topic
  • APlusAutoParts
Posted March 07, 2014 - 07:32 AM
i just switched from a 2013 yz to a 2014 yz450 brand new i started it last night for the first time and at idle with cold start pulled out right a away the first 8 to 10 inches of the pipe was glowing reg, i know that pipes do that but i just didnt expect to see that at an idle and so much of the pipe. just wanted to know if you guys thought that was normal?
  • lkeffersyz
Posted March 07, 2014 - 07:59 AM
Check your water to antifreeze ration too much antifreeze can make it got since its thicker than water or your water pump could be bad
~Yz426F&Crf250R~
  • lkeffersyz
Posted March 07, 2014 - 08:04 AM
I have a yz 426 f which is where the 450 came out of and if it gets a little low on antifreeze or anything in warm weather it gets really hot
~Yz426F&Crf250R~
  • tang426
Posted March 07, 2014 - 08:33 AM
My 426 glows red at idle. The pipes are very thin to save weight. They dent easy when hit
  • APlusAutoParts
Posted March 07, 2014 - 08:49 AM
you guys are saying check my water and antifreeze when i started it last night it was about 20 degrees i live in ny and it was running for about 30 seconds before it was glowing the motor wasnt even warmed up yet
  • lkeffersyz
Posted March 07, 2014 - 08:50 AM
Yes I agree! But I put aftermarket water pump and it has impressed me the pipe hasn't been red yet! Maybe you should try just putting aftermarket pumps in everything. It sure helped me.
~Yz426F&Crf250R~
  • lkeffersyz
Posted March 07, 2014 - 08:53 AM
So it's still glowing?
~Yz426F&Crf250R~
  • k.g
Not normal!!! The bike is toast! Might as well part it out, as the engine is done for.
:smirk:
Not really. It's completely normal. There's probably 400 million threads about the same thing.
  • lkeffersyz
Posted March 07, 2014 - 08:56 AM
The bikes not toast you don't know what your talking about. It's cooling issues that's minor for now. Try letting it get more fuel maybe it's running too lean that causes heat and also make sure it has enough oil!
~Yz426F&Crf250R~
  • lkeffersyz
Posted March 07, 2014 - 08:57 AM
Haha yeah there is a lot of threads on cooling but that'd take a lot of digging lol.
~Yz426F&Crf250R~
  • k.g
Posted March 07, 2014 - 09:01 AM
Please read.
http://www.thumperta...ing-bright-red/
  • lkeffersyz
Posted March 07, 2014 - 09:03 AM
That will help if he had fmf or aftermarket exhaust. So best thing to do is just read up on a lot of this stuff.
~Yz426F&Crf250R~
  • k.g
Posted March 07, 2014 - 09:11 AM
My 100% stock 01, 03, 04 and 12 yz250f did the same thing.
  • lkeffersyz
Posted March 07, 2014 - 09:12 AM
Yeah yzs dot tend to run a little hot
~Yz426F&Crf250R~
Posted March 07, 2014 - 09:38 AM
No, it applies directly here. And the threads referenced were not about cooling, they are about glowing exhausts specifically.  It also applies directly to stock exhaust pipes, since the factory header is the same high grade, thin wall titanium that the aftermarket uses.  It has nothing whatsoever to do with the cooling system, either, as the pipe isn't cooled by that system, and the cooling system has very little overall effect on the heat of combustion at an idle, nor on exhaust temperatures at that speed.  Header construction plays a part in this; lighter pipes will glow more readily because it takes less to heat them.  Mine glows with the factory Ti header, but not with the heavier stainless pipe I run with.
The glow indicates that the pipe has reached about 8-900 ℉.  The source of the heat is, of course exhaust gas, which normally runs at temperatures around 1300 ℉ under "cruising" loads, and up around 1650-1800 ℉ at full throttle.  The reason the pipe doesn't glow at those times is simply due to the convective cooling done by the air flowing over the moving bike.  The exhaust temps are higher than normal at an idle on the YZ450 because of its relatively high idle speed, very aggressive cam timing, and the retarded ignition timing at an idle.  Add to this, it's an EFI bike, so the fuel system will keep the mixture rich as long as the coolant temperature is lower than the normal operating range, even if the "choke" is off.   It's really pretty normal overall, and although there are different degrees of it, it's very seldom anything at all that anyone should worry about.
Good advice.  You might want to follow it.
  • lkeffersyz
Posted March 07, 2014 - 09:46 AM
I'd say the only thing it wouldn't be that may be a factor is fuel tuning. Lean motors run hot I had a yz 125 burn the piston because the oil in it got cold and clogged the carb. Therefore little to no oil and little gas that was the only time if ever seen a 2 stroke overheat. Be careful with fuel to air ratios!ImageUploadedByThumper Talk1394214346.457197.jpg
~Yz426F&Crf250R~
  • APlusAutoParts
thanks gray i really appreciate it
Posted March 07, 2014 - 09:57 AM
I'd say the only thing it wouldn't be that may be a factor is fuel tuning. Lean motors run hot I had a yz 125 burn the piston because the oil in it got cold and clogged the carb. Therefore little to no oil and little gas that was the only time if ever seen a 2 stroke overheat. Be careful with fuel to air ratios!attachicon.gifImageUploadedByThumper Talk1394214346.457197.jpg
~Yz426F&Crf250R~
And, of course, it did that while it was idling with the header glowing red, right?
Not relevant.
  • zeuszuki
Posted March 09, 2014 - 12:20 AM
Not relevant.
Humour him Gray, i am still trying to work out if hes serious or trolling ...
  • Bremer120
Posted March 09, 2014 - 07:02 PM
I'm just happy a perfectly functional water pump isn't being replaced...
