wr400f case bearings
3 replies to this topic
  • chrisleika
Posted March 07, 2014 - 02:06 AM
Bike Yamaha WR400F 1998. year
I splited the case and saw that 2 bearings in left crankcase was closed from one side:
1. Outer side of drive axle bearing vas closed - there goes seal
2. Outer side of main axle bearing where goes clutch push rod in left case
So i have question, theese 2 bearings should be open from both side or close from outer side???
Bearings from inside the case
Bearings from outside the case
Thank You
  • bg10459
Posted March 07, 2014 - 05:52 AM
I'm working on a YZ250 right now, but the bearings should be similar.  The left side output shaft bearing (83A915) is open on both sides, no seals, but I can't see how a seal on the outide could hurt.  The left side main transmission shaft bearing (6004RUD) is sealed on the outside or the side facing the clutch actuator arm housing.  Hope this helps.
  • chrisleika
Posted March 07, 2014 - 10:14 AM
left side main transmission shaft bearing (6004RUD) is sealed - in my photo did you mean the small or big bearing is sealed??? Sealed itself or outside is another seal?
In my picture big bearing - drive axle bearing was sealed itself and + outside ist another seal
  • jojo1224
Posted March 07, 2014 - 11:24 AM
They are both supposed to be sealed on only one side and the seal is supposed to be on the outside. If you put them in backwards the seal will pop out from the oil pressure, at the top of your first picture is where the oil feed line is inserted into.
