426 Complet Clutch on 400
6 replies to this topic
  • mikseven
Posted February 26, 2014 - 05:29 AM
Hi all,
I'm considering to buy a complete WR426 Clutch (Basket, Center Hub, Pressure Plate, Spring, Push rods, actuator and plates).
Is it installable on a WR400?
I need to replace my Clutch due to eccessive wear and with the 426 it will be possible to mount the newest Rekluse Products.
Thank
Mik
  • mikseven
Posted March 02, 2014 - 12:46 AM
Nobody can help me?
Mik
  • rosedog
Posted July 11, 2014 - 07:08 AM
Hi mate. Did you end up doing this? I was searching fir an answer for the same question so i can fit a rekluse to my 400.
  • mikseven
Posted July 11, 2014 - 07:34 AM
Hi Rosedog,
yes, it works.
You need to replace entire Clutch with the 426 model. Actuator, primary drive, hub, Friction/Drive Plates, pressure plate and springs.
If you need to install a Rekluse, only actuator, primary drive, Drive/Friction Plates are needed. Pressure plate and spring are not used.
If you find a Z-start pro is good enough. A core Exp is better.
  • rosedog
Posted July 11, 2014 - 08:57 AM
Cheers mate. I brought a 2002 wr400 as a parts bike has a seized engine. Was just looking to see if the clutch was the same as 2002 426, but i think it is different. As far as i can tell it has 1 less plate and 1 less spring. So will continue to search i think. Thanks for your help.
Edited by rosedog, July 11, 2014 - 08:59 AM.
  • mikseven
Posted July 11, 2014 - 12:57 PM
Yes The 400 has a clutch with 5 Springs directly derived from xt & tt series. The parts are completely swappable. If you are lucky you can find a Rekluse z.Start, the 1st version. It works great. I ran some Italian Rally Championship Races without problems.
The only advantages of the 426 clutch is that you can use more recent Rekluse Systems.
  • rosedog
Posted July 11, 2014 - 11:48 PM
Thanks mate. It seems a bit hard to find info on these bikes now, and alot of blokes font want to share their knowledge. Your a legend
