2013 Wr450f how to remove the neutral start
4 replies to this topic
  • m.kealy
Posted February 17, 2014 - 04:16 AM
Does anyone know how to bypass the neutral starting switch so I can start my wr450f in gear ?
Please help
  • Navaho6
Posted February 17, 2014 - 07:39 AM
It should start in gear with the lever pulled in.  If you want to bypass that safety function (or replace the oem lever) then follow the wires going from oem clutch lever to connector behind the headlight shroud.  Cut the wires, leaving room to solder the ends. Solder the wires coming out of the connector behind the headlight.  Seal the exposed wire and tuck it behind the shroud.  Remove the wires coming out of the clutch lever.
Edited by Navaho6, February 17, 2014 - 07:45 AM.
  • Krannie McKranface
Posted February 17, 2014 - 09:07 AM
He's not talking about the Clutch overide swtich, he is talking about the neutral only switch.
There is a recent post about it that I started.
  • Navaho6
Posted February 17, 2014 - 10:20 AM
 In that case, maybe this helps:
http://www.thumperta...l#entry11330676
Edited by Navaho6, February 17, 2014 - 10:23 AM.
  • m.kealy
Posted February 17, 2014 - 03:01 PM
Thanks guys I'll get on it on the weekend
