wr400f stator cover aluminum spacer between LH engine case
7 replies to this topic
  • YAMAHA109F
Posted February 16, 2014 - 04:40 PM
I'm sure this aluminum spacer is an aftermarket, that sits between the left engine case and the stator cover. Anyone know why it would be there?
  • exracer2
Posted February 16, 2014 - 04:59 PM
Flywheel weight ?
  • YAMAHA109F
Posted February 20, 2014 - 05:03 PM
Anyone else have any ideas? Can't be the only one.?
  • Krannie McKranface
Posted February 20, 2014 - 05:14 PM
High output stator
  • jim-in-so-ore
Posted February 20, 2014 - 06:43 PM
Years ago I had a wr 400 that I put a Steahly flywheel weight on. It had the spacer like you discribe, it was needed because the flywheel weight made the flywheel wider (and heavier)
  • GuyGraham
Posted February 21, 2014 - 08:01 AM
Take the stator cover off and have a look!
Posted February 21, 2014 - 12:46 PM
Why not?
  • YAMAHA109F
Posted February 26, 2014 - 05:17 PM
I think I'll have to take it apart and find out sometime. Not today though. I just got my license plate today so when it warms up outside (maybe in june) I'll see if the headlight is up to snuff. I still run that on the ac current. Thanks for all your replies.
