Stock header on my 06 YZ450?
9 replies to this topic
  • sped68
Posted February 11, 2014 - 12:38 PM
I picked up a new to me 06 YZ450 last fall and have spent some time this winter going through it.  I'm quite happy with the state I have the bike in now except for the header.  When I first got it I had noticed the header was quite close to the coolant hose going into the pump housing.  I figured maybe it was just rotated down.  Since then I have gone through the top end, changed the header gasket etc and tried to position the header farther away from the hose but when I tighten the header flange it seems to settle it back to the same position.
I have been looking at pictures of other 06's and in comparison my header appears to not extend as far forward as others, and possibly the radius of the bend is smaller.  I really don't think it is bent but is it possible it has the wrong header on it?  I'll attach a picture (hopefully), so you can see what I mean.
Posted February 11, 2014 - 01:56 PM
Looks like the whole stock '06 system to me.  I have one at home.  I'll look at the header this evening.
  • sped68
Posted February 11, 2014 - 06:40 PM
When I look at this picture of a stock 06 yz450 its header definitely looks like it extends out farther than mine.
  • writebrian
Posted February 11, 2014 - 09:46 PM
That does look awful close. A cheap safety precaution would be fiberglass header wrap on the portion. I have my whole header wrapped in it as I kept burning my pants on my aftermarket Akrapovic header with no guard. No problems since. A full roll cost you less than $10 bucks at Autozone.
  • sped68
Posted February 12, 2014 - 10:32 AM
That is an option I suppose but it would be tight even getting the wrap on the header, it would be touching the hose.
Does anyone have a picture they could put up of the FMF powerbomb header installed on a 06?  From the pictures I have found it seems to be a shorter pipe than what is on the stock 06 anniversary edtion picture I linked to.  I'm mainly curious how far out from the side of the hose it comes.  I have been reading conflicting info on the powerbomb fitment on 06's because they say they fit 03-06's even though the stock headers are different from 03-05 and 06.
Posted February 12, 2014 - 12:02 PM
Well, you appear to have a 426 header on there now, so... Unless the pipe is less than 1/8" from the hose, don't worry about that part.
The power bomb fits both as advertised.
  • sped68
Posted February 13, 2014 - 05:49 AM
I think I am leaning towards the FMF powerbomb header to replace the pipe that is on it then.  Any issue running the powerbomb with the stock muffler?
  • writebrian
Posted February 13, 2014 - 09:47 AM
Fluid going through that short pipe is in serious motion. I dont think there is much opportunity for heat transfer to take place. Look how close your header comes to the bottom of your right radiator tank at the bottom. Does that bother you?
Edited by writebrian, February 13, 2014 - 09:47 AM.
  • sped68
Posted February 13, 2014 - 12:59 PM
The problem is the header is so close that it started to melt the old rubber hose.  I have replaced the hose but obviously don't want it to melt through on the new hose.  Now I'm sure i could fit some heat wrap between the hose and header but it bugs me that it is so close and it's obviously not the correct header anyhow.
  • writebrian
Posted February 13, 2014 - 04:21 PM
If it's melting the hose then you better fix it! I will restate, header wrap is a cheap fix with no down side. I would actually wrap the hose rather than the header and use the existing upper and lower hose clamps to hold it in place. Fixed!
I can touch my header wrap with my bare hand after riding all day. It's obviously warm but does not burn the hand.
  • 0 replies
  • Hot  47 replies
  • Hot  113 replies
