Spark Plug Weep Hole - "Burp" after washing cycle.
11 replies to this topic
  • mebgardner
Posted February 03, 2014 - 11:24 AM
I had an interesting "Huh??" moment in the garage.
I was testing for boil-over / header glowing conditions at idle, after changing FI maps and Idle / CO settings.
The spark plug weep hole started belching fluid.  "Huh?? What the...?"
I looked again, it was clear liquid (not antifreeze color). Oh, I'd just washed the cycle a few days ago. Water got in there and sat there...
So, that's my point.
You wash your cycle, you put it up until you play again, and the water sits in the spark plug hole until you use it again (and it then burns off).
Cover the weep hole before washing... There's no description in the Users Manual to suggest this (it says to plug the exhaust pipe hole).
  • Krannie McKranface
Posted February 03, 2014 - 11:47 AM
No, do not cover the weep hole, blow it out with compressed air.
That is why it is there.
You have so much crud up in there that the weep hole is not working.....it's supposed to drain immediately.
Edited by TheKoolAidMadeMeSick, February 03, 2014 - 11:48 AM.
  • mebgardner
Posted February 03, 2014 - 01:01 PM
OK, thanks.
Will do...
  • cubera
Posted February 06, 2014 - 07:23 PM
Krannie why the name change?
Posted February 06, 2014 - 07:36 PM
It was just a whim, but you can no longer change profile name more than once every 6 mo.....so I'm stuck with it for a while.
I kinda like it.  After all, it's true.
  • William1
Posted February 07, 2014 - 05:31 AM
After I wash a bike, I used compressed air to blow it off then I heat the bike up riding around slowly on my private road. I let temps get to be about 190 then I put the bike away. Takes about ten minutes of slo putting and I know there are no puddles of water in nooks and 'krannies' that can promote rust/corrosion.
Posted February 07, 2014 - 06:16 AM
+ bike on stand, running in gear, wd-40 on the chain, then chain wax on the chain, and another 'detail' of compressed air, in the throttle tube, lever perch pivots, peg pivots, etc etc.
Then a quick spray of MB-1 on the plastics, a pat to the seat, and then lights out.
  • ggamster
Posted February 07, 2014 - 06:23 AM
You know, i noticed the times when I have the most difficulty starting my bike are after I have let it sit after washing it. I wash my bike after every ride however and I'm always frustrated because it wouldn't start. I adjusted the CO as you and I have discussed in the past. It didn't seem to make a difference when starting it after washing it. However, I noticed that after I did get it started if I didn't wash it and just let it sit for a couple days the bike would start right up. I wonder if that is a partial cause of the difficulty of starting the WR?
  • mebgardner
Posted February 07, 2014 - 06:28 AM
You guys are thorough. I do really appreciate all these good tips.
Really, thanks very much.
Posted February 07, 2014 - 06:46 AM
Yeah, you prettty much cannot wash a bike and then not start it.
Corrosion everywhere....
  • cubera
Posted February 07, 2014 - 06:48 AM
Yeah I know you've had your experiences with the Halloween bikes. I've have migrated to the WR this year. Interestingly because the WR is the closest I could get to having a reliable 450XC-F from a Japanese maker and it saved a couple of grand to boot. The trusty 650R is too much bike for me in the technical crap I ride these days so I sold her back to the guy I bought her from. The 530 is on a stand in the garage with a leaky CS seal and square rims. She's getting some TLC then sold. So it's down to a do it all bike from Northern AZ one track to D38 desert to Baja the WR will have to do it all with minimal fuss. So far, so good!
Back on topic: Personally I gave up washing bikes after every ride (unless muddy conditions). I'll blow the dust off and wipe it down some then go ride again. I'll do a good spray wash with a power washer (yes a power washer) being careful of  the weep hole, exhaust opening, lubrication points, controls, and electrical before service on the bike like oil/tire change and before and after a race or major ride. After it gets wet it gets the water blown off and a wipe down. I use a grunge brush on the chain and then chain wax. Generally I'll start it after a wash and run it to operating temp to help "cook" and "shake" any unwanted water out of it. If I didn't have a good maintenance schedule for lubrication points I would avoid the pressure washer all together.
Edited by cubera, February 07, 2014 - 06:54 AM.
  • ggamster
Posted February 07, 2014 - 06:56 AM
Here in Southern IL, we have little to no option to wash your bike.  It is a mud pit for seven months of the year.
