'03 wr450 starter problems
6 replies to this topic
  • motormike1
Posted February 02, 2014 - 09:59 PM
I know this has probably been  covered somewhere in the forum but I can't seem to find it.  I have an '03 wr450 and an '03 wr250 that neither starter is working just a click on the 450 and nothing on the 250.  I've tried jumping with a car battery but no luck.  Does anyone have a line on starters that are cheaper than OEM?  Any other suggestions would be appreciated.
  • flyandride
Posted February 02, 2014 - 10:09 PM
It may be something other than the starter.  The relay is under the seat, locate it and short the two big terminals on it and see if the starter works.  Could be the relay on the 450 if you're just getting a click.  On the 250 you say you're getting nothing, could be the clutch lever switch or neutral switch.
  • Krannie McKranface
Posted February 03, 2014 - 06:37 AM
FUSE UNDER TANK
CORRODED GROUND LINES
BATTERY WITH BAD CELL
Try jumping directly to the starter terminals, not to the battery, to check the starter
  • motormike1
Posted February 03, 2014 - 07:58 PM
Thanks for the help, I'll dive in this weekend.
  • bobpara
Posted February 04, 2014 - 11:02 AM
I have an 06 WR 450 and I had the strangest thing happen
I thought my starter or something was fried
Turns out it stopped right at TDC and didn't have enough oomph to turn it over
From the guys on this site they said it was a common problem
Maybe yours too
  • DeepPurplishBlue
Posted February 04, 2014 - 11:47 AM
Maybe yours too
It is common...
when this happens you just bump it with the kickstarter to get the engine turning again
and the electric starter usually is able to do the job again
  • JVP
Posted February 05, 2014 - 11:09 AM
Replace the relay under the seat.  I had the same problem and found it cured that problem.
