2010 YZ450F No Fuel
7 replies to this topic
  • coppolaj
Posted February 02, 2014 - 04:58 PM
My injector does not receive power. Where does it get it's power from and how is it triggered.
Posted February 03, 2014 - 07:24 AM
It is powered from and triggered by the ECU.
  • coppolaj
Posted February 03, 2014 - 08:08 AM
Does something send a signal to the ECU letting it know to trigger the injector
Posted February 03, 2014 - 08:59 AM
The ECU takes inputs from the whole set of sensors to determine how much and when to trigger the injector and the spark plug.  The signal from the pickup, or trigger coil is the base point for both, as it provides engine RPM and crank position information.
  • coppolaj
Posted February 03, 2014 - 02:03 PM
Ok. The original wire that wraps around the plug wire for the tach. came loose from the other end and I have no idea what it was connected to or if it will effect the bike
Posted February 03, 2014 - 04:02 PM
Does the bike run?
  • coppolaj
Posted February 03, 2014 - 06:40 PM
No
Posted February 04, 2014 - 06:55 AM
To begin, the tach/hour meter is an aftermarket part, not factory installed, so the bike does not depend on it to run in any way.  The free wire on the unit is supposed to go to a power source.  What may have happened, depending on how it was installed, is that there may be a bare wire at the point where the power feed was spliced on that is now shorting things.  Start by downloading a manual, if you don't already have one:
http://www.yamahaown...ook.com.au/?r=0
http://www.yamaha-mo...uals/index.aspx
Then, go over the entire harness for loose, dirty, or damaged connectors.  Follow that by testing the stator, rectifier/regulator, and other components as described.
  • On January 15, 2017
  • 5 replies
  • Hot  50 replies
  • Hot  38 replies
