Need some help with Yamaha WR450 2008
14 replies to this topic
  • mandolin
Posted February 02, 2014 - 10:04 AM
Hi.
I'm new on this forum.Need some advice from you guys.
My starter motor has just died. Yamaha WR 450F 2008
Did a litle searching on the internet,ebay and so one..
my question is this:
are the wr450F 2003 and the 2008 starter motors the same?will it fit and work fine?
Here are some pictures i got from the search.They look similar......
Thank you!
  • flyandride
Posted February 02, 2014 - 04:27 PM
What exactly is it doing and are you sure it isn't a problem somewhere else?  Like sometimes the auto decompress sticks retracted and the starter doesn't have the balls to turn the engine over without it.
I see some starters on ebay from Ricks Motorsports that says it works from '03 to '11
  • stevethe
Posted February 02, 2014 - 06:32 PM
The early starters they post as fitting do not, ask me how I know.
Buy a factory new one, if it's bad. Don't be in a hurry to install it either, yea just don't ask about that either. Take off the small starter cover and align the gears to the new starter. Don't just jam it in.
  • mandolin
Posted February 03, 2014 - 05:57 AM
ok..so they are not the same...?
  • Krannie McKranface
Posted February 03, 2014 - 06:29 AM
2003 - 2006 motor is not the same a 2007-2011
  • mandolin
Posted February 03, 2014 - 08:44 AM
not even the starter motor?
Posted February 03, 2014 - 09:01 AM
Dude, two people have answered your question already.
What more are you looking for?
  • mandolin
Posted February 03, 2014 - 10:27 AM
 ok,thank you
Any idea where i could find a 2008 model?
Posted February 03, 2014 - 11:49 AM
bikebandit.com
yamaha.com
  • stevethe
Posted February 04, 2014 - 06:59 AM
Try Boats.net for the best price on a starter.
  • bobpara
Posted February 04, 2014 - 11:00 AM
Log onto bike bandit
Spec out a motor for both years
See if they call out the same part no
  • mandolin
Posted February 04, 2014 - 11:03 AM
look at the first post.In the photos attached...they dont have the same part no
  • ftl900
Posted February 04, 2014 - 03:31 PM
Then it seems pretty clear.  They are not the same.
  • Road Rage
Posted March 02, 2014 - 03:04 PM
The Starter went on my 07 WR450, turns out the auto decompressor was gummed up and not working properly, the extra load on the starter caused it to burn out, I had mine rewound and new brushes, all ok now. I clean my auto decompressor everytime I check valves now (I spray solvent into the mechanism to degunk it. Since the rebuild (costly) I found www.rockymountainatv.com carries aftermarket starter motors at a fraction of the cost. Good luck with the repair.
  • stevethe
Posted March 02, 2014 - 07:54 PM
Looks like they go up to 06' on RMATV.  They changed the starter motors in 07'.
There is a guy on eBay that lists a 06' fitting don't believe him I had to send it back.
