YZF Silencer on WR
12 replies to this topic
  • Kahuna
Posted January 08, 2004 - 06:41 PM
Will a YZF silencer fit on a WR?
Thanks
  • tctrailrider
Posted January 08, 2004 - 07:06 PM
Yes and no. The 450 exhaust will not fit the 400 or 426, but if you stick to the same year yes. 00-02 are all interchangable and the 03-04 are also.
  • PBDBLUE
Posted January 08, 2004 - 07:17 PM
Ditto on that. I run a YZ can on my '04 WR450. You do need the YZ rubber mounting hardware and a longer bolt though. Easy way to lose about 4 lbs.
  • Math
Posted January 09, 2004 - 03:17 PM
I know from a previous post you are looking for the 426 and I also know that another guy on this forum called "Sylvain" changed his stock WR silencer for the YZ426f silencer and he was very happy with it. Guys will correct me if I am wrong but I think that 01 and 02 WR/YZ frames are exactly the same so there should be no problem
  • HaremScarem
Posted January 09, 2004 - 05:12 PM
Correct, but you will need a different bolt where the can attaches to the rear of the subframe.
  • WRSTEVE
Posted January 10, 2004 - 06:53 PM
To make it a little more custom add, the YZF sub frame, you will not be disappointed :)
  • Sylvain
Posted January 12, 2004 - 12:28 AM
Math is right about me being happy with a stock YZ pipe on my WR. Performance and weight wise. But be careful with the throttle near houses. As long as you idle it near the housing you'll be fine but if you decide to use it on the road, :), it really barks too much for street use.
  • Greg_C
Posted January 12, 2004 - 04:36 PM
What would you guys expect to pay for a stock 03/04 YZF Silencer? I posted on the YZ side and one guy offered to sell me his old pipe for $100 I was hoping for more like $50.
  • sqwidget
Posted January 12, 2004 - 04:47 PM
would a yzf450 exaust be better then a aftermarket exaust for a wr450?
  • FTD
Posted January 12, 2004 - 04:53 PM
I picked up a used FMF PowercoreIV 2 with 2 caps (regular~loud~ and the quiet cap) for $100.
$50 is the going rate for a used YZF pipe.
Found this... looks pretty USED!!
http://cgi.ebay.com/...item=2454002638
Hoss
  • Greg_C
Posted January 12, 2004 - 05:12 PM
FTD, the guy emailed me back and said that he will let it go for $50. But I will have to pay shipping from Ca. to Va. I have an 04 WR so I will need an 03 or 04 pipe. Thanks for the help.
  • FTD
Posted January 12, 2004 - 05:29 PM
I guess my ADD is kicking in... :) I didn't follow the post too well!!
Hoss
  • treehugger
Posted January 16, 2004 - 08:51 AM
I got a 98 YZF silencer to fit on my 03 WR450 and am really happy with the performance increase. I only use it at the track though because it is loud. I used this same pipe on my previous bike, 00 WR400. The pipe fit directly on to the 400, but had to be modified slightly to fit the 450. It does require a jetting change due to a slight lean condition.
