YZ 400f problems
8 replies to this topic
  • Devil1
Posted January 23, 2014 - 07:36 PM
Hey folks,
I recently acquired a 99 400f and I'm having some issues.
I bought this rebuild kit for the carb
http://pages.ebay.co...lobalID=EBAY-US
After the rebuild I finally got it started but only with the throttle applied.
So here is what it does.
Starts only with throttle applied.
Backfires while running with light throttle applied
Will not idle.
Will accelerate fine under moderate to full throttle with no backfiring.
I have a YouTube video of the first run you may or may not get a better understanding
Please keep the comments bout the video to yourself It was just the first ride in the subdivision.
  • Yammer-Hammer
Posted January 23, 2014 - 11:19 PM
Sounds like idle is set to low and that you have a partially blocked pilot jet. To start this off what is the elevation and temp in your area?
  • Devil1
Posted January 24, 2014 - 07:18 AM
At sea level or no more than 100ft and 45degrees.
  • Yammer-Hammer
Posted January 24, 2014 - 11:14 PM
I would start by pulling the bowl off the carb and figuring out what size jets are in it. Do you know how to check the jet sizes and what each jet is?
  • Devil1
Posted January 25, 2014 - 07:40 AM
The shop has tried jetting it with no change.
  • Thommo_400f
Posted January 27, 2014 - 01:56 AM
Give us your jetting.
Need
Needle model and clip
Eg OBDTM clip 3rd from top
Main jet
Eg 175
Pilot
Eg 45
Also inspect fuel screw as it could be missing the o-ring.
  • jakeh_16
Posted January 27, 2014 - 02:45 PM
yes I own a 99 yz400f.
also at sea level.
I run ethanol but on petrol I ran a JD jetting kit blue needle, 45 pilot, 165 main
you say you have just recently acquired the bike, it is an old bike and likely has worn valves and seats, causing fuel/air mix to leak into exhaust and backfire, clean ur carb well and try a JD jet kit but its most likely a problem in the head
  • jakeh_16
Posted January 27, 2014 - 02:47 PM
also was it running ok when you first got it?
  • Devil1
Posted January 27, 2014 - 08:15 PM
also at sea level.
It had the trans rebuilt a few years ago and at that time the valves were checked and were fine. It hasn't really been run since then as my friend moved across the Us and developed the carb issue. I was turned onto a a part possibly being put in upside down I the carb. Another owner said his did the same thing. I'm unsure of what the part is called.
I'll get the info requested for you guys.
  • Hot  50 replies
  • Hot  47 replies
  • 10 replies
  • Hot  36 replies
