Used eBay carb prep before install ?
2 replies to this topic
  • NVdan
Posted January 23, 2014 - 12:44 PM
I posted about a new carb to replace my original 1998 WR carb about two weeks ago. The opinion was to get a 2005 or up used YZ carb.
Got one on eBay. A 2006, with the hot start cable, got new throttle cables also. I removed the float bowl and it looked good inside. The gas smelled fresh.
What would you all recommend doing to the carb before I install it?
I am thinking take it apart, clean it , check passages, new pilot jet & gaskets. Anything else?
From reading about older carb problems, a bunch of you have gone the eBay used carb replacement route, any major problems?
Thanks, Dan
Edited by NVdan, January 23, 2014 - 03:03 PM.
  • Krannie McKranface
Posted January 23, 2014 - 05:53 PM
That depends on how many times you want to take the carb on and off, until you get it clean, jetted, and fully functioning.
Only once ???
  • flyandride
Posted January 23, 2014 - 07:54 PM
I put an 09 YZ carb on my WR, got if from another TTer.  I cleaned it and put my jetting kit in it and it started in 2 kicks.
