08 wr450F Draining & Adding Coolant
3 replies to this topic
  • JokerWR
Posted January 22, 2014 - 04:49 PM
How's it going guys?
Just picked up a 08 wr450f and want to drain the coolant and add engine ice instead.
unfortunately don't have the service manual.
how do i drain ALL the coolant from the bike?
will 1/2 gallon of engine ice be enough?
Thanks!
Edited by JokerWR, January 22, 2014 - 05:33 PM.
  • JokerWR
Posted January 22, 2014 - 05:33 PM
Edited by JokerWR, January 22, 2014 - 05:34 PM.
  • Krannie McKranface
Posted January 22, 2014 - 05:51 PM
There is a drain plug with a copper washer on the water pump side.
Start the motor, open the drain, take of the radiator cap, shut off the motor.
let it drain
Start the motor again for 5 sec
Drain some more.
Close drain bolt.
Add fluid to top of radiator fins.
Start motor.
Watch for swirling in the radiators when throttle is applied and big bubbles (air pockets)
Add more coolant to top of fins if needed.
Put cap back on.
Ride it
Check levels again.
  • JokerWR
Posted January 22, 2014 - 06:28 PM
let it drain
Drain some more.
Close drain bolt.
Start motor.
Put cap back on.
Ride it
Check levels again.
Thanks!
