Increased Rear Sprocket Size Question
3 replies to this topic
  • Katzat
Posted January 20, 2014 - 08:39 AM
Gentlemen,
I'm a newb at this dirt bike thing. Late 2012 as a father/son hobby dealio I bought an '08 YZ450 from the son of a local shop owner. The kid was an avid MXer. The bike ran well and was cheap so I bought it and rode it throughout 2013 as it was. Riding with more experienced TT'ers I met here resulted in a laundry list of maintenance items that I am completing as I write this. Hence my set of questions.
1: Chain: I replaced the original O-Ring chain (kinked at one point due to bad link installation) with a new X-Ring chain. The replacement chain has a master link. I found that after installing the new chain, the master link got removed by the chain guide when I spun the rear wheel backwards. Do you generally recommend installing the chain without the master link (pressing it on)?
2: Chain Guide: The bike had 14:48 sprockets on it for track racing. While I ride on the track some with my son, I found that gearing the bike down was necessary for enjoyable trail riding. Based on the recommendations of a very good trail rider, I have replaced the rear sprocket with a steel 51 tooth sprocket. After installation of the sprockets and chain the chain guide clearance in the chain guide was definitely deflecting the chain at the sprocket. It also seems tight (narrow) and I blame that for the removal of the master link clip when rolling backwards. But between the tight deflection and the apparent narrowness of the existing guide, the rear tire didn't roll nearly as smoothly as it did with the old crimped chain. So I removed the chain guide and it rolls smoothly, but not as smoothly as it did before. I blame this on the newness of the chain and the new bearings in the rear wheel. I read here that a TM DesignWorks chain guide is the answer, but their website does not mention anything about more room for the larger sprocket or how high I can go with it. Can someone tell me what they have done in this regard? Will a new chain guide allow the master link to roll through backwards without removing it?
3: Sprockets: I replaced both the sprockets with inexpensive steel ones to 12:51. The recommendation was made to go to 12:53, but even with 12:51, I'm gearing down over 20% from the existing 14:48. Due to snow, I won't even be able to test this for a while, and I'm thinking of getting a spare 13 tooth sprocket as well for when I ride on the track or less technical trails with my family. What are your recommendations in this regard?
Thanks.
  • Hoosier-Daddy
Posted January 21, 2014 - 02:20 PM
I ride the same bike but an 09 primarily in the woods. I have found 13/51 to be my happy place on sprockets. Going 12 on the front I think is overkill and will wear chain and slider faster. A 53 on the back will have to be pretty far forward, which I believe wears your guide faster assuming you have a fairly fresh 114 link chain. I too use steel sprockets for cost and durability.
Something else you might consider is the heavier gytr flyweel. Bike seems much easier to ride in low rpm range with that. Correct spring rates and setting the sag is also a must.
Many people rave about the rekluse clutch too. I cant bring myself to drop the cash.
As for the clip popping off, might make sure your fresh master link is the correct one for your chain. And keep that thing going forward!
I think the sprockets are really a personal preference and desired speed is a big factor. At 13/51 with heavy flywheel it is easy for me to keep the bike running in tight and has enough top end to get me going as fast as I care to go. I am sure someone else will have a different opinion.
  • Hoosier-Daddy
Posted January 21, 2014 - 02:25 PM
I do know they make a narrow xring chain that adresses clearance issues on these mx bikes. D.I.D. VT2narrow. That has the option of clip style or rivet style master link. I have not ran one personally but maybe someone here has..?.
Posted January 21, 2014 - 03:07 PM
I run a Regina ORN-6 O-ring chain, which is NOT one of the narrowest sealed chains available, and there is no particular problem with chain width at any of the possible conflict points.  As to your loss of the master link clip, I will say that you are wrong about how you lost it.
On any good, premium grade chain worth having, The outer plate of the master link is a tight press fit over the pins, and it's a common mistake to not get the plate down far enough to allow the clip to seat fully into the grooves.  Also, since you are "new to this stuff", it may not have occurred to you that there is a right and wrong direction to have that clip pointing.  The closed end of the clip must lead and the open end must trail as the chain is rotated in its normal direction.  There is no way to disengage a correctly installed clip by simply rotating the wheel backwards, any number of times.
  • 0 replies
  • Hot  30 replies
  • Hot  28 replies
