could a burnt up clutch cause bike to stall
6 replies to this topic
  • hilliskx713
Posted January 19, 2014 - 02:52 PM
could a burnt clutch cause a bike to stall in neutral? my bike dies as soon as i let the clutch out in neutral
  • Valosity
Posted January 19, 2014 - 03:00 PM
Not exactly... You could have to adjust the cable, because maybe the clutch still is engagaing in nuetral. Can you ride it fine and shift fine?
Could be a possiblity tho
  • hilliskx713
Posted January 19, 2014 - 03:06 PM
it shifts fine i noticed a problem when it started to stall mid air while jumping went back to the truck and it would start and run fine as long as i had the clutch in as soon as i release it bike dies and it in neutral
  • zilla
Posted January 19, 2014 - 03:31 PM
If it's truly in neutral it won't stall..   I'd say that ya got something bound up  in there.. Prolly between the clutch and tranny.  Pull the cover and look.
  • Wild Alaskan
Posted January 19, 2014 - 03:38 PM
should not ever stall from being in neutral regardless of clutch condition
  • zilla
Posted January 19, 2014 - 03:47 PM
One more thing, when started will it do this when in gear?
  • hilliskx713
Posted January 19, 2014 - 04:14 PM
found out that the guy i bought the bike from installed a works clutch perch and he ran the kill switch wires under the claps so they were smashed and when i would let go of the clutch it would short the switch causing all the problems. still glade i took my clutch apart because the steel plates were toast. thanks for the inpute
KX450F fuel pump by mzeim
Dirt Bike   Make / Model Specific   Kawasaki   KX450F
  • 8 replies
Which years KX 450 to get? by IraqvetUSMC
  • Hot  83 replies
Kawasaki KX450F 2017 by Chris.GVS
  • Last review by cygrace74mx
  • On December 02, 2016
Kawasaki KX450F 2016 by motomike81
  • 12 reviews
  • Last review by Nystrom7
  • On January 11, 2017
What was/is the best sounding bike you have owned? by akosi
  • Hot  70 replies
