Kick start won't go down?
5 replies to this topic
  • joshrf450
Posted January 18, 2014 - 02:40 PM
The lever won't go down on my yz450f. But the engines not siezed
  • Trauger
Posted January 18, 2014 - 03:08 PM
open up the clutch cover or pop off that side of the case could be kick start gear, clutch basket, or something under there. How do you know the bike isn't seized
  • joshrf450
Posted January 18, 2014 - 03:29 PM
The piston can be moved
  • rmxdan
Posted January 18, 2014 - 03:36 PM
Is this related to the other thread you started earlier?
http://www.thumperta...rt-should-here/
IIRC there are alignment dots on the kickstart shaft and quadrant (no4 in diagram) that need to be positioned a certain way.
Edited by rmxdan, January 18, 2014 - 03:37 PM.
  • joshrf450
Posted January 18, 2014 - 04:08 PM
Yes it is, I bought the bike and the casing behind the kickstart was cracked and the lever won't go down and the parts missing
Posted January 18, 2014 - 04:25 PM
Looking at at the damage in your other post, I would guess that the kick start assembly is also broken.
