rebuilding forks
7 replies to this topic
  • 03yzfbert
Posted January 18, 2014 - 08:07 AM
How much fork oil does the 03yz450f fork take in oz not mm from the top?
Posted January 18, 2014 - 09:56 AM
The manual specifies 20 ounces, but as I recall, it takes a little over a quart to do both sides.  What's the problem with measuring the level?  It is the only really accurate way to fill them, and the level will make a pretty big difference in the fork's behavior.
  • 03yzfbert
Posted January 18, 2014 - 07:23 PM
I don't want to spend the money on the fancy tools just trying to get around it.
  • RandAybarra
Posted January 18, 2014 - 10:28 PM
I used a small syringe and some plastic tubing. Worked great.
Posted January 19, 2014 - 07:43 AM
What fancy tools? For oil level? Take a straight section of coat hanger, mark it at 110mm, and use it as a dip stick.
  • Hoosier-Daddy
Posted January 19, 2014 - 01:30 PM
[quote name="grayracer513" post="11308898" timestamp="1390146219"]What fancy tools? For oil level? Take a straight section of coat hanger, mark it at 110mm, and use it as a dip stick.[/quote
I like that idea! One quart did both forks on my 09 when I replaced seals. Thats not including inner cartridge.
Posted January 19, 2014 - 05:12 PM
Yes, it would have, but that is a completely different fork, too.
  • 03yzfbert
Posted February 08, 2014 - 06:52 PM
Yep finally rebuilt them today put 20oz in what the book calls for and good to go the pvc driver worked perfect
  • Hot  36 replies
  • Hot  50 replies
  • 10 replies
  • On January 15, 2017
  • Hot  47 replies
