New motor, does out when I put it in 1st gear?
8 replies to this topic
  • DieselJoe
Posted January 12, 2014 - 06:40 AM
Okay so I had my motor completely redone, all new bearings, transmission, timing chain, top and bottem end, cylinder, head, cams etc. when I put it in first gear when it's cold it dies out. If I roll it forward then put it in gear it's fine, but then revs up a little bit and idles higher in gear. When warm it will go into gear without dying but again idles higher in gear then in neutral, what could be the problem? I partially blame it on the hydronic clutch, only because I don't like it I feel like a cable clutch pulls the clutch in farther and a cable seems more reliable to me.... Any other ideas? Kinda weird. Also this didn't happen before the rebuild, that I can remember anyway
  • kx125rida
Posted January 12, 2014 - 06:46 AM
Check clutch and maybe idle.
Posted January 12, 2014 - 08:26 AM
Year and engine size?
  • 250premixer
Posted January 12, 2014 - 10:28 AM
my bike does that too let it warm up...
  • DieselJoe
Posted January 13, 2014 - 04:47 PM
It's a 2003 yz450f
Posted January 13, 2014 - 08:38 PM
How much free travel is there at the clutch lever?
  • DieselJoe
Posted January 14, 2014 - 10:18 AM
None it's hydraulic
Posted January 14, 2014 - 11:56 AM
If the clutch is also new, it may need time to wear in enough that it stops dragging.  That happens a lot of times when aftermarket plates are used instead of the OEM or premium quality items.  If you only replaced the friction plates, it's likely that the steels are not truly flat.  Once in gear, it should not creep more than a very small amount, if at all, and you should be able to put the bike back in neutral at an idle.
If it idles faster in gear, and/or if the idle "hangs" at a higher speed for a time after it's revved up, you have either you idle set too lean, an air leak in the intake, or a tight intake valve.
  • DieselJoe
Posted January 14, 2014 - 01:32 PM
The clutch is not new at the time of the engine overhaul, but it's not stock either....
  • 9 replies
  • 10 replies
  • 0 replies
  • Hot  36 replies
