YZ426 problem
21 replies to this topic
  • cole40
Posted January 09, 2014 - 09:52 AM
Hey guys, my yz426f runs great now and is a blast but today out of nowhere the kill switch stopped working. Should I just replace or is there anything else i should check first
Posted January 09, 2014 - 10:17 AM
Be sure it's plugged in and that the connectors aren't dirty or corroded.  Otherwise, just replace it.
  • cole40
Posted January 09, 2014 - 12:50 PM
You sir just saved me 16$. One of the wire end had came off. Thanks!
  • missouri-man
Posted January 10, 2014 - 11:44 PM
Do u guys know what plastic will fit a 98 yz426. I wna go all yellow and black and i cant find them for the 426
  • Yammer-Hammer
Posted January 11, 2014 - 12:24 AM
Theres no such thing as a '98 yz426f. The '98 was a yz400f
  • missouri-man
Posted January 11, 2014 - 12:33 AM
The jug says itsa 426 and fram vin 10th is a w i thot that ment it was a 98? What year would it be ? Guy i got it from said it was a 2002
Posted January 11, 2014 - 08:46 AM
You just hijacked this thread.  Bad Internet manners.  When you have a completely separate thing to ask, please do so in a new thread.
There are several possibilities, but it's clear that the top end of your engine does not match the frame it's in.  You have a '98 frame, but the 426 was built between '00-'02.  It may even be that the bottom end is from a '98.  If you post a picture of the right side of the engine, I can tell you whether that's the case.
Aftermarket parts of any kind are becoming increasingly difficult to find for the '02 and earlier bikes.  Shop eBay for some.
  • missouri-man
Posted January 11, 2014 - 12:01 PM
Ya sorry bout jacking the tread i new to this and dont no how to start a new one
And i post a pic in a few
  • missouri-man
Posted January 11, 2014 - 12:07 PM
Theres the pic
  • Yammer-Hammer
Posted January 11, 2014 - 12:49 PM
The W indicates a 1998 model year. If the jug say 426 that means that someone has swapped a cylinder from a 426 and piston from a '03 450 onto the 400 bottom end. But looking at that photo i can tell that that case and bottom end is off a 426. So its a 1998 yz400f frame with a yz426f engine swapped in.
Edited by Yammer-Hammer, January 11, 2014 - 12:51 PM.
  • Yammer-Hammer
Posted January 11, 2014 - 12:58 PM
The first photo is of my '98 yz400f right side case, and the second is of the right aide cover off my '02 yz426f. You can see the difference between the two were the oil feed line bolts up.
Edited by Yammer-Hammer, January 11, 2014 - 01:06 PM.
  • missouri-man
Posted January 11, 2014 - 01:00 PM
Alright thanks do u no what plastic will fit it
  • Yammer-Hammer
Posted January 11, 2014 - 01:15 PM
Welcome, and i dont know about yellow plastics because i was never able to find any. But i do know that UFO sells black plastics for the 400.
Here is the link to the UFO plastics
http://www.ufoplasti...del.php?brand=6
Edited by Yammer-Hammer, January 11, 2014 - 01:17 PM.
  • missouri-man
Posted January 11, 2014 - 01:30 PM
Thanks guys
Posted January 11, 2014 - 02:51 PM
The engine appears to be a 426.
  • missouri-man
Posted January 11, 2014 - 03:03 PM
The valve cover says its 5 valves and the jug says its 426cc
  • Yammer-Hammer
Posted January 11, 2014 - 03:32 PM
The 400 had a 5 valve head aswell. you can put a 400 head on a 426 cylinder.. Post a pic of that oil feed line area i showed you and i can tell you for sure what motor you have
  • missouri-man
Posted January 11, 2014 - 03:34 PM
It looks just like the bottom pic but i will go take u one
  • missouri-man
Posted January 11, 2014 - 03:43 PM
Will this work for u
  • Yammer-Hammer
Posted January 11, 2014 - 03:59 PM
Yup that would be a 426 engine.
