2014 wr450
11 replies to this topic
  • Thearmyman83
Posted January 07, 2014 - 07:13 AM
Has anyone had the radiator gaits over the exhaust catch on fire from the glowing header? Last night I put a different tune on it last night(Aussie map) let it idle from cold maybe 2 minutes and turned it off. 10 seconds later the rad guard was in flames.
  • mebgardner
Posted January 07, 2014 - 07:17 AM
Wow!  No, I have not.
  • scott525
Posted January 07, 2014 - 12:16 PM
I saw my header glowing way more with the Aussie map than the other maps. I immediately changed mine to the fmf map
Glad I did now!
  • comp123
Posted January 07, 2014 - 12:41 PM
Never thought about mapping having anything to do with this situation. My 2012 wr450 ' with the FMF mapping'  has had two fires at the header. The first time it was leaves or sticks that had collected in the header area. The second time I stopped in high brush when I noticed a small brush fire starting under the bike. I have also seen the header glow bright red at times.
  • Thearmyman83
Posted January 07, 2014 - 02:36 PM
In the tuning which affects the header turning red ignition or fuel?
  • scott525
Posted January 07, 2014 - 02:51 PM
My guess would be fuel. Lean condition.
  • scott525
Posted January 07, 2014 - 02:54 PM
Well I guess I might as well pack a lunch that I can cook over a fire!
I may try adding +1 on the fuel at idle.
  • Krannie McKranface
Posted January 07, 2014 - 03:02 PM
More like + 5
  • funt
Posted January 07, 2014 - 03:06 PM
Sounds like it needs the CO adjustment.
  • scott525
Posted January 07, 2014 - 03:13 PM
More like + 5
Really?
I know my needs it. Just dont want to stop by the dealer and/or waste money on the FI tool.
  • Thearmyman83
Posted January 07, 2014 - 03:48 PM
Feel stupid what is CO?
  • funt
Posted January 07, 2014 - 05:04 PM
I think carbon monoxide.  My other bike has diagnostic mode built in to the speedometer.  There's a CO setting that you can raise or lower to change the fuel mix at idle.  The lowest power tuner setting is centered at 4000 rpm and 1/8 throttle.  The CO adjustment would effect the idle more directly.
Edited by funt, January 07, 2014 - 05:08 PM.
