'13 WR450 Oil Filter Change - Replace the O-Rings?
10 replies to this topic
  • mebgardner
Posted January 07, 2014 - 07:09 AM
The 2013 WR450F Users Service Manual (comes with cycle upon purchase) shows 3 ea. O-Rings that are specified as "New" (for replacement) during an oil filter change.
You guys do this (replace them)?  Or, just reuse the one's that are already there?
Thanks,
Bob
  • beezer
Posted January 07, 2014 - 07:14 AM
Reuse them.
Posted January 07, 2014 - 07:54 AM
I bought a set of 4 (to include the larger O-ring as well as the 3 small ones) before I did the first oil change on my 426 ten years ago.  Since then, I've used one or two of them a couple of times as the ones in place show signs of wear, compression, etc.  Then I replace the one I used.
Not even close to every time, just once in a while when it looks like it's called for, and it's nice having them on hand.
  • mebgardner
Posted January 07, 2014 - 10:26 AM
OK, thanks for the help calibrating my expectations on the O-Ring life.
Got it :)
  • albertlui
Posted January 11, 2014 - 12:48 AM
my 06 WR450 use the stock set o-rings for 7 years, about 30,000KM and then starts leak.  :applause:
I also agree to have it on hand, but will only change it when leak.
  • Krannie McKranface
Posted January 11, 2014 - 05:52 AM
Never changed one
  • DangerRanger245
Posted September 28, 2015 - 05:11 PM
I had my 2006 YZ450F for 9 years. Never replaced them, never leaked
  • jmd426
Posted September 28, 2015 - 06:03 PM
Never changed mine owned it 4 years
  • Chaconne
Posted September 29, 2015 - 07:35 AM
Got it :)
+1 on reuse.
But I always double (ok maybe triple maybe more, ok ok ok OCD alot :ride: ) check for leaks or seepage on all points including drain bolts and oil pressure bolt.
  • Nuklhed
Posted September 29, 2015 - 04:40 PM
I re-use.  Although, I did pinch the upper one putting the cover back on.  Sheared it right off.  Fired up the bike and a leak appeared.  Took it off, found the sheared o-ring, and promptly bought several for spares.  It's a bitch to find motorcycle store open on Sunday!
  • mch
Posted October 01, 2015 - 11:49 PM
Always good to have an extra set on hand.  I don't recall the exact details, but a friend had told me that once he was not able to re-use the o-ring because it had expanded on him after dis-assembly and would no longer fit in the grooves.  Perhaps he left it off all night, it dried out, etc.?  I have a big o-ring on a leaf canister for my pool and that has expanded pretty good, so I can see it happening.
