12 wr450 engine noise
7 replies to this topic
  • wrkronic450
Posted January 05, 2014 - 03:20 AM
Is it normal for a yammie engine to be noisy. I have only done 600km on the bike, and I have read they are tight from new but it seems a little loud compared to other bikes I have had
  • gimped up
Posted January 05, 2014 - 03:27 AM
Can you describe the noise?
  • wrkronic450
Posted January 05, 2014 - 03:59 AM
Piston noise. You can hear every stroke. Am I just being paranoid.
Does it just need to be worn in more
  • gimped up
Posted January 05, 2014 - 04:03 AM
What octane you running?
  • gimped up
Posted January 05, 2014 - 04:07 AM
If your running too low of octane it will not sound right.
I had this issue with my yz400 and wr426.
  • wrkronic450
Posted January 05, 2014 - 04:35 AM
Running 98 octane is it any thing to worry about?
The other day when I got my power tuner I set it at the recommended idle rpm 1900-2100 seemed to start sweet and run good.
After a quick burn around the local mx track and getting it hm. I cleaned it and checked rpm it had dropped back to 1800 and was a pig to start
  • beernutt
Posted January 05, 2014 - 10:45 AM
WRs have noisy clutches. Does the sound change while idling in neutral clutch in vs clutch out? The noise you're describing is common with a warm bike idling in neutral with the clutch not pulled, usually goes away when you pull the clutch.
Posted January 06, 2014 - 11:24 AM
http://www.thumperta...e/#entry4444207
