YZ 426 timing chain
12 replies to this topic
  • Donkim
Posted January 04, 2014 - 07:12 PM
I have a YZ 426 and there is a rattling noise coming from what i think is the timing chain. Its a 2001 model and i bought it used about 2 years ago.  How often should the timing chain be replaced, and could this be the problem.
  • peaceofwork
Posted January 05, 2014 - 10:29 AM
post a video clip of it running it will help
  • Donkim
Posted January 05, 2014 - 04:10 PM
https://www.dropbox....05 19.57.25.mp4
This is a video of the bike running. I have checked all of the skid and protector plates.
  • peaceofwork
Posted January 05, 2014 - 07:26 PM
grayracer is a wizard on these kinds of things maybe he will chime in. In the past I herd things like put a hand on the skid plate or rear shock spring to see if it stops the rattling sound another one is kicker gear staying engaged ?. pop the valve cover and just see if the timing chain is lose?  take off both side covers and check fore something loose? . Maybe its internal like the rod bearing on the big end or a crank bearing-I,m just guessing but I think its like a ticking time bomb
  • Donkim
Posted January 05, 2014 - 07:47 PM
I've checked all of the external parts on the bike and also checked the clutch. I thought it might be the timing chain or the tensioner. Thats where im looking next. I went on YouTube and it sounds like others have the same noise.
  • Arizo
Posted January 06, 2014 - 02:54 AM
I have a little ratle noise also but i think its normal.
  • Donkim
Posted January 06, 2014 - 06:57 PM
How long have you owned the bike? I just started riding the bike for the last two seasons and didn't notice it until this last summer.
  • Arizo
Posted January 06, 2014 - 10:25 PM
2 years and still got the bike
  • peaceofwork
Posted January 07, 2014 - 03:58 PM
of the 3 that I have had I never had noise like that in your video out of them I usualy run 15/40 in them what weigh oil are you using?
  • Donkim
Posted January 07, 2014 - 04:24 PM
The same as you
Posted January 07, 2014 - 04:32 PM
Actually, I can't normally tell anything from the sound recordings people post of their bikes.  The sound quality is normally so poor that I can't determine anything about it, particularly with all the racket these things make when they're perfectly healthy.  Yours is pretty good, compared, but the only thing I heard was it sounds like it's running a little fast.
Timing chains should be replaced annually or thereabouts as maintenance.
  • etuke
think its time to tear into that engine,dosen't sound normal to me.
  • peaceofwork
Posted January 07, 2014 - 04:47 PM
just because you have not put in a chain do it, and shim the valves while your in their and run it and hope for the best ?
  • Hot  50 replies
  • Hot  36 replies
  • Hot  28 replies
