Engine light after stock MFD removal?
12 replies to this topic
  • tripledigits1
Posted December 31, 2013 - 10:02 PM
New to the WR450 here.  I have a 2012 which will be switched seasonally from off road to supermoto.  I've removed the stock display and installed TT voyager.  Went for a short test ride this afternoon, and the engine check light came on shortly after starting ride.  I haven't had any luck in finding out if this is related to removal of stock display.
Any info would be appreciated.
Thanks,
Jeff
  • Navaho6
Posted January 01, 2014 - 07:06 AM
Did you modify any wiring?  It is more than likely just an electrical glitch.  Have the dealer check it with the diagnostic tool.  I removed my speedo and lights.  Filled the connectors with dialectric grease and covered them with tape.  No issues at all but I am not running an after-market speedo.   I use an hour meter which has an internal battery and I carry a Garmin gps which tells me everything I need to know.
Edited by Navaho6, January 01, 2014 - 07:08 AM.
  • tripledigits1
Posted January 01, 2014 - 08:43 AM
No wiring mod other than adding brake light switch and tapping into tail light ground. Thanks, and Happy New Year!
  • funt
Posted January 01, 2014 - 10:19 AM
I think it might be throwing a code for no speed sensor signal.  I was expecting the check engine light to come on when I removed mine but it never did.  Do you have the competition ECU yet?
  • tripledigits1
Posted January 01, 2014 - 10:29 AM
No comp ECU yet, but I understand that's the best way to go for numerous reasons.  Thanks. Great forum, gents.
  • funt
Posted January 01, 2014 - 12:54 PM
You could probably use a resistor to trick the ecu into thinking the speed sensor is still installed.  I don't think the competition ecu cares if a speed sensor is there or not.
  • Corkster
Posted January 01, 2014 - 02:15 PM
There is already a post covering this.  For 2012 onwards models, removing the stock speedo will trigger the engine warning light, with or without the comp ecu.
  • Navaho6
Posted January 01, 2014 - 04:22 PM
Well, I removed my speedo and ran it with the oem ecu and competition ecu and the engine check light has never come on.
  • Corkster
Posted January 01, 2014 - 05:06 PM
Did you remove the speedo sender?
  • funt
Posted January 01, 2014 - 06:52 PM
I removed mine.  I'm in USA though.  I think the Australia ECU is different than what we get.
Edited by funt, January 01, 2014 - 06:58 PM.
  • woods-rider
Posted January 02, 2014 - 10:04 AM
I removed the stock computer and am running a Voyager also. Never had the CEL come on. I removed the whole speedo cable and sensor and replaced with a standard style aluminum wheel spacer. My bet is that you unplugged some connection behind the headlight when you were removing the stock computer.
  • Corkster
Posted January 02, 2014 - 02:07 PM
Hmmm, interesting point.  I did install the whole GYTR offroad kit that comes with the Aussie bikes, so I will have a look at what else has been connected/disconnected.
  • Corkster
Posted January 06, 2014 - 02:30 PM
You were correct.  When I replaced the speedo bracket with the associated wiring, the light went off.
