Making a 426 into a 450?
3 replies to this topic
  • Tyler426
Posted January 06, 2004 - 01:16 AM
I was thinkin about how the 426 and 450 have the same bore and the 450 has a longer stroke. So would it be possible to put a couple 450 parts into a 426 to make the stroke the same as the 450 or is something like that a stupid idea?
  • Gadsen
Posted January 06, 2004 - 09:20 AM
If it works, let me know. Hopefully, it will only require the rod and crank! You may want to get a few extra woodruff keys! :)
  • PowerFiend
Posted January 07, 2004 - 08:43 AM
Put in the Powroll 2mm stroker crank and a 2mm larger piston. Should be cheaper and easier.
  • PBDBLUE
Posted January 07, 2004 - 09:10 AM
The 450 motor is physically quite a bit smaller than the 426. I would be surprised if the rod length and deck height would be correct for a 426 top end. I'm pretty sure the 450 cylinder will not bolt up to the 426 cases.
