Grey Wire question
1 reply to this topic
  • Alzy
Posted December 30, 2013 - 01:06 PM
On my 08 WR 450 that came out of Edmonton, Canada, the grey wire does not come out the other side of the connector clip.  I assume this means it is not connected and I do not need to pop out the grey wire or cut it.   Is it only the bikes for the US that need this mod carried out?
  • William1
Posted December 30, 2013 - 01:25 PM
If the wire is not there, either your bike did not come with it or it was removed. Too many 'gray market' bikes go over the border to know definitievely if your is untouched.
If compelled, you can check the wiring harness thoughn I'd not worry about it unless you wanted to connect it to soften the hit. If you, simply connect to ground.
Make you you check the throttle stop. Confirm the slide rises to the top of the carb throat.
