2006 YZ450f 50th Anniversary
Yamaha YZ450F 2006
73 replies to this topic
  • Zabrow187
Posted February 13, 2015 - 09:43 AM
#61
Thanks and the first one I'm not sure what really happened it to but it failed right away, the only thing I could figure out was it hit the header and shorted it out. I hope to get the 2nd one in next week but right now I'm just using the battery and hooking up the battery tender when she's parked. I haven't found too many good reviews on any of our stators so if it makes it a year I'll be happy cause next year I'll be doing the WR conversion on the crank to get the 100 watt trail tech stator and 5th gear so I don't have to feel like I'm gonna blow her up to keep up with the sport bikes or even my buddies wr400 on the smooth haul roads. The graphics I have are the ebay knock off style so they were pretty cheap.
My bike has 5 gears, did the transmission change from 06 to 09? I don't have $1200 to swap my crank and everything, hopefully this one lasts.
  • 700rScott
Posted February 13, 2015 - 10:08 AM
#62
The 06 was the first year for our style and still have 5 gears but the YZ 5th gear is .952 reduction and the wr is .840 reduction so you drop the rpms from like 500 rpms from 4th to 5th to like 1000rpms or 1500rpms so you can get higher speeds without messing with you sproket ratios. When I have my street tires on I'm running like a 15 and 45 so I lost a bit of my bottom end power just to keep the rpms low on the roads. I'd like to do a 13 or 14 front sproket with the 45 in the rear so get me a happy medium when I get sumo wheels.
The Crank is only needed if you wanna do the wr stator but the 5th gear is like $100 in parts plus labor if you have someone tear it down. I'm getting a few other things and if you buy everything new it's like 2K but most guys will try to buy stuff off ebay to cut 25-50% off in used parts.
Edited by 700rScott, February 13, 2015 - 10:17 AM.
  • Zabrow187
Posted February 13, 2015 - 10:14 AM
#63
I run 14/44 and can cruise pretty well with my SM setup, but swap to 14/49 for dirt so i'm not beating up my clutch too much.
  • 700rScott
Posted February 13, 2015 - 10:22 AM
#64
I'm running the stock gearing cause I tried the 14/49 and it was a little too high for my liking for the dirt so I went back down. It does really well for everything but the long strait aways. My buddies wr400 ran away from me on a 4 mile stretch of old RR bed and he wasn't even revving it out.
  • 700rScott
Posted March 07, 2015 - 01:39 PM
#65
She's getting closer! I got the Hinson steel clutch basket in, Rekluse Z pro installed, Zip Ty fuel screw, HD Stator in for round two since the 1st HD stator didn't last long, a Tusk rear brake switch and now the connections are in the air box, flasher wired in, the rear fender and air box back on. It should be ready to go next weekend since I just have some minor wiring to do now.
D1B8DDA9-47D6-4414-B6AE-E13D18893C30_zps
540CE008-368D-4BEA-B854-6314B82AD3EC_zps[/URL]
C5F84C2D-7B22-4C6A-A50A-92BB10C76FA3_zps
Edited by 700rScott, March 07, 2015 - 01:40 PM.
  • AZ42racer
Posted March 09, 2015 - 08:57 PM
#66
700rScott.  Looks really nice. Nothing better than having a true YZ450F with the power for dirt and the freedom to gear up or down depending on where you spend most of your time on or off road.  I started with:
And ended up with:
I'm pretty happy with mine.  Still have to put on the DOT knobbies and eventually convert to 18" rear wheel (have parts just not done yet)
  • 700rScott
Posted March 11, 2015 - 08:56 AM
#67
And ended up with:
Thanks and over the quad there's so much more freedom especially when you have a plate on it. I'd still like to upgrade to something like a Husky FE501s eventually but I think for the next few years I'll hold on to this. I'm hoping this stator holds out to charge the battery a little and I'll just put a Wr 5th gear in it next season to get more top end cause I still can't get over how my buddies Wr400 was so much faster on a old long RR bed. The 18" rear rim with a 140/80-18 S-12 tire are on the list to get next. The 130/70-19 S-12 tire is no where near the width 110/90-19 dunlop tire was but I think the tall lugs will make up for it a little since I'll be riding more in sand this year.
Edited by 700rScott, March 11, 2015 - 09:03 AM.
  • 700rScott
Posted March 23, 2015 - 07:18 AM
#68
I've got a few more to dos checked off and tried firing her up but she didn't want to even try. The rekluse, Hinson basket and R6 head light switch are all done. I still have to wire in the 12 O'Clock tail light, fix a head light wire and figure out the no starting issue but I'm pretty certain putting in the oem stator will take care of that. I had high hopes of the electrex since it's made in europe but after the 2nd one frying and this one not working, I'm back to the oem stator and using the battery tender. I'm gonna try the pro cycle one a little later and hopefully that does the trick of getting some charging power when she's not plugged in. The Wr tank fits on fine but the WR shrouds don't fit on so well so I have to fight the bottom screw to go in.
B8AB3795-238F-49D5-AAE1-DB7939F10FF4_zps
07459B0D-1503-41E3-BE9E-6A182A2D76A8_zps
  • 700rScott
Posted March 30, 2015 - 08:10 AM
#69
She's almost ready to hit the trails and road. The 12 O'Clock Labs tail light is wired up, petcock isn't leaking anymore, the head light is rewired but I still need to put the oem stator back in, sag set and put the new chain slider on. I'm hoping to get her fired up this weekend.
AEAE1432-A251-4F24-8037-644210EA8819_zps
0F2E917F-7B4D-4B38-AAED-FC1812CCC3D8_zps
F2A3EE96-72A4-4726-9464-58B88D8FB7C2_zps
DC1CBEAB-0FA0-437A-B562-6C8F262E4CDD_zps
6AC45B36-9961-4A79-B3D9-B9BA220BDC9F_zps
A9D16580-6CFF-42D9-B2DE-854C39A643CE_zps
0A3AF6A1-B44A-4816-BB9D-C6908520D9AD_zps
C07E448B-5A33-4A3D-9EE4-A2958105AEE1_zps
  • 700rScott
Posted March 30, 2015 - 08:17 AM
#70
  • 700rScott
Posted April 13, 2015 - 11:30 AM
#71
I finally got the bike running this weekend and just took it around the block. I noticed between the S12 tire and the old dunlop, the S12 is much slicker on the pavement since I almost dumped it making a turn.
15034436-49B4-4C29-9872-20E5814AD245_zps
36B27065-F57E-4F9A-93C1-33BAD0451070_zps
EFE1FC85-33B3-461B-B95E-C729148F6EA3_zps
41DF39CC-E6E1-4A0F-852C-45625E9761FC_zps
  • 700rScott
Posted September 02, 2015 - 08:57 AM
#72
It's been a while since I've updated this. I had it up for sale but took it off since a few things came up and didn't want to be without a bike for a year, I'm gonna try to keep it and still get the Beta cause you can't have just one  :lol:
On top of the mile in ashland with my friends 300XC.
FC0A0914-DA29-4658-81ED-992CF9135A48_zps
I was having some electric problems so I took everything off but the tail light.
Oops, don't walk a bike down a hill in gear and running even though the rekluse wasn't moving the bike forward when you start down the hill. :banghead:
E930E177-3E85-4EA4-8EC7-27328DC61A1E_zps
58E4EFCF-6B59-4C91-9890-8A427EC172A4_zps
I added ktm fender brace to try to reduce the tail light from bouncing too much.
543A4F14-82FA-459A-930A-249C65E1B11A_zps
After jersey I finally put the brake pedal cord on since the stumps try to get you.
E9A30158-D582-4D33-B2A1-C591BD78009F_zps
I'm putting the lights and a new head light on so I moved the CDI box to the air box so hopefully the light fits a little better.
74BD2142-A03E-4D60-A99C-8962C9F54CE9_zps
22DDD6DD-944A-48FD-B821-8D3D3290FCBB_zps
BBF93830-AC44-4AEE-95F5-C7FF5F555BCA_zps
New ktm style head light.
1B0F057D-2724-43A3-BC61-FD1F9F8A7846_zps
New supermoto wheels that should be here in 2-3 weeks and the nipples will be black so they'll look a little different.
06621909-44B9-438B-8872-9CC32FF62A1E_zps
With Continental Contiattack SM tires.
724AE492-8BC0-4409-964B-4FAD1A81E6F6_zps
  • 700rScott
Posted September 14, 2015 - 07:51 AM
#73
She's all back together, I also changed out the foot pegs and put in a standard sparky instead of the quiet core for the area's I know I don't need to worry about for sound. I'll be picking up the Sumo wheels and tires tomorrow but I won't be able to try them out for a few weeks since I'll be riding every sunday for three weeks helping the SJER guys with the race October 12th weekend.
E3C4C094-3F97-46F7-BB35-460787C5446A_zps
F9CC60D5-0EE9-4C59-87CB-1F32CDDD4BD8_zps
8EE20290-5E51-468B-BF3C-2A5B5EAB1B36_zps
369603DF-904A-4C7B-8113-DC1411F59261_zps
I went to start her up after changing the oil and I forgot to screw in the dip stick in so I had oil all over.  :banghead:
41F46C01-E197-468D-8997-2699E9A89401_zps
  • 700rScott
Posted September 16, 2015 - 05:48 AM
#74
My wheels came in yesterday but I'm waiting on the bolts for the brake rotors so they should be in today. I'll be mounting them in a few weeks when I'm not riding dirt for a little bit and I hope the rear doesn't rub on the chain cause I ordered a Graves chain block but I need to take the swing arm off to drill and tap the bolts for that so it should be a winter project.
ECDE4564-2DA9-43CA-AE4D-5B209D9C21A9_zps
C9D4D479-0BFF-4AF9-82EA-BFA96A3F7AB1_zps
A3510097-E5E3-4DD7-81B8-B16826038F1C_zps
Yamaha YZ450F 2006 by ThumperTalk
Yamaha YZ450F 2006
  • 41 reviews
  • Last review by Yzrider1023
  • On November 30, 2016
  • Hot  33 replies
  • 3 replies
06 yz450f troubleshooting help by wet_willy05
  • 15 replies
