Swingarm and linkage seals
2 replies to this topic
  • D-rek07
Posted December 15, 2013 - 06:25 PM
I'm replacing the seals in the swingarm and shock linkage on my 2006 WR450f. I only need the seals. Will I have to go to a Yamaha shop or can I get these in the internet somewhere? I already know about the pivot works kit that has everything. Thank you.
  • Krannie McKranface
Posted December 15, 2013 - 08:41 PM
Pivot works
All Balls
OEM is best.
You can order all the parts individually on the TT store.
  • GuyGraham
Posted December 16, 2013 - 10:23 AM
Any bearing factor will be able to supply the seals
Just get the sizes, either of the seals or by direct measurement
Loads cheaper to buy as a generic engineering component than from Yamaha
Such an example in the uk is http://simplybearings.co.uk/
I never buy seals or bearings from Yamaha, unless they are specials
Here are the sizes (from a 2008 model) - yours maybe different being 2006. compare the part numbers on here http://www.ronayers....CHE-C22846.aspx
Bottom shock seals                         17 x 24 x 2.5
Linkage Oil Seals                            25 x 32 x 4 - 4 off
'U' Arm Oil Seals                             22 x 28 x 4 - 2 off
Swing Arm Oil seals                        Inner 22 x 28 x 6 - 2 off,
                                                       Outer 28 x 35 x 4 - 2 off
Edited by GuyGraham, December 16, 2013 - 10:25 AM.
