Sag setting for 2012
11 replies to this topic
  • Navaho6
Posted December 06, 2013 - 02:46 PM
What is the best race sag for the '12 - '13?
  • Krannie McKranface
Posted December 06, 2013 - 07:18 PM
Same for all years:
Start with 100/25mm and forks at the top of the clamps.
Fully geared up, at least a half tank.
That will give you the most neutral handling, if you can achieve that number without having the change front and rear springs.
The 100 is more important than the 25, for now, if you can't.
  • Navaho6
Posted December 07, 2013 - 06:56 AM
Thanks, Krannie, but everywhere I've read about sag for this bike, they mention sag settings at 90 or mid 90's.  My older WR would be not be rideable at those settings.
90 mm - http://www.motoonlin...-yamaha-wr450f/
and per the Yamaha Factory tech's, 90mm here (paragraph 3) - http://www.dirtbikew...ead.php?t=89708
The shop manual lists 90 - 100 mm.
Would like to hear from those of you who have this bike and have played with the sag settings.
Edited by Navaho6, December 07, 2013 - 07:07 AM.
Posted December 07, 2013 - 08:22 AM
My 2003 and 2008 manuals both say 90-115mm.
That article, that guys says " 90mm sag and 5mm up in the fork clamps".....
Now that is certainly ride-able, but man oh man would you have some wicked over-steer!
I suppose for riding that is all tight and flat, that would be fine, but for rough terrain, IMHO, you would have to crank you steering damper down to -3 for the straights, and to -10 for the corners just to be able to turn the bars without swapping.....
  • Navaho6
Posted December 07, 2013 - 08:31 AM
That what would definitely happen on most bikes.  I guess the only way to find out is to try different settings.
It's a shame but most of the time I ask other guys what their race sag setting is, they don't know and don't care (Mostly the slow guys).  Not that I am super fast but I can tell a difference in +/- 3mm in the rear.  I almost never pull my forks up in the clamps.  Stability goes South real quick.
Posted December 07, 2013 - 09:40 AM
I have a small x-mini track near my house. Dry, pot-holed straights,  notchy blow-out bermed corners.
I take my bike up there, bring a hammer, a tire iron (to hit the spring nut with) a 17mm socket (for the high speed compression) and a small blade screw driver for the clickers, and spend an hour playing around. Sag usually ends up being 98/23 (no pack, no full riding gear, but full tank of gas) to 105/26 fully loaded.
I already have a 6.4 rear spring, so getting it perfect is really hard.
  • Navaho6
Posted December 07, 2013 - 10:43 AM
What bike?
  • WR 911
Posted December 07, 2013 - 10:46 AM
I'm set at 103mm for moto and desert.
  • Navaho6
Posted December 07, 2013 - 12:49 PM
WR911, where do you have your forks at in the triple clamps.  Shop manual says to set them at +5mm above.  I set them at 0 (flush).
  • WR 911
Posted December 08, 2013 - 09:25 PM
Flush for desert and up 5mm for moto. I also run 17mm offset clamps.
  • Navaho6
Posted January 20, 2014 - 05:51 PM
To update:   I tried 95mm, 98mm, 100mm and 104mm race sag settings.  104 was awful.  So was 95.  100 really works the best.  Turns good and yet still very stable in the sand.
Posted January 20, 2014 - 06:59 PM
cool
