03 450 HELP!
9 replies to this topic
  • -Biggins-
Posted November 30, 2013 - 10:12 PM
Hey guys, I'm getting my 450 ready to sell. I noticed that the timing was way off when I took the valve cover off. So I timed it, piston at TDC, and then adjusted the valves. I got them in spec. Put it all back together, noticed that it had way more compression, but it wont start. Help
  • -Biggins-
Posted December 01, 2013 - 10:57 AM
Anybody? It seems like it sounds different when I kick it over. Won't start. Anything guys?
  • shortburb
Posted December 01, 2013 - 05:39 PM
The two variables you changed were timing and valve clearance. If timing is off it won't start. If valve clearance is too tight it won't run/hard to start.
Recheck those first
  • -Biggins-
Posted December 01, 2013 - 08:12 PM
Recheck those first
yeah I set the timing and the clearances at top dead center on the flywheel, timed it, now I put it to TDC and check it, and the timing is WAY off. It sounded different when I started it. Going Tuesday to get some shims.
  • -Biggins-
Posted December 07, 2013 - 12:16 AM
So the exhaust valves measured .27 mm and the intakes at .14 mm. Set the timing according to TDC on flywheel. Still won't start. Has visible spark, compression, air/fuel,( the plug was wet ), has timing, what am I missing?
  • -Biggins-
Posted December 07, 2013 - 12:17 AM
I know the exhaust valves are a little more than the clearance but is it that causing it to not start? It also back fires about every 10th kick.
  • vic2340
Posted December 07, 2013 - 07:37 AM
My friend and I got the timing wrong by a little once, it was on his 03 crf450r. It wouldn't start. I think you have the same issue. Make sure your cam chain and cams are where they should be. One tooth difference and their is no way the bike will run.
  • -Biggins-
Posted December 07, 2013 - 12:26 PM
I got it as close as I could. It was almost perfect. If you go one tooth up, it's too far, one tooth back it's just a little under the case.
  • vic2340
Posted December 07, 2013 - 07:15 PM
Well that means your timing chain is super stretched, order an oem one pronto. They are like 25 bucks on rockymountainatv.com in there oem section.
  • -Biggins-
Posted December 07, 2013 - 07:54 PM
will that make it not run? All I'm trying to do is make it run for the guy that wants to trade his yz 250 2006 :)
  • Hot  38 replies
  • Hot  28 replies
  • Hot  47 replies
