Replacing the Cam Chain?
10 replies to this topic
  • opie
Posted November 30, 2013 - 06:28 PM
Hello all it's been a while.  I have a question about replacing the cam chain.  I have a 2012 YZ450 with about 75 hrs on it and need to do some work replacing parts after a pretty good crash.  My question is should I just look at replacing the chain now while the bikes is out of commission or should I wait?  I've replaced the chain on previous bikes at about 100 or so hours and every time it wasn't even stretched. Has anyone had any issues with their chains by waiting until it was at 100 plus hours?  It is regularly ridden and raced but at a Vet B level.  Any replies would be greatly appreciated! Thanks!
  • Falcon 1
Posted November 30, 2013 - 06:42 PM
Opie,
Most all cam chains are the same across all makes and models of dirt bikes. I normally replace my cam chain every time I replace piston and rings.. however. Honestly the chain looks like new when I replace it, I just feel better knowing I have a new cam chain with a fresh top end. Honestly, the cam chain will last much longer than the piston.. so you could probably get 100 hours out of it with no problem. I think people ask for trouble when they never replace the cam chain with hundreds of hours on them..
You should have no problem changing the cam chain every 100 hrs.
PS:
I have replaced countless cam chains, and never had one that was stretched. Probably could have got another 100 hrs out of the ones I've replaced. However, I tend to "over service" my bikes.
Good luck.
Posted November 30, 2013 - 06:52 PM
Timing chain: $20
Potential disaster caused by timing chain failure: $3000
Do the math.
Same with valve springs, BTW.
  • Yzflier977
Posted December 01, 2013 - 06:32 PM
Grey, what's the recommended service schedule on replacing the valve springs?
  • opie
Posted December 01, 2013 - 08:10 PM
Thanks for the replies I really appreciate them.  I'm with Yzflier and curious Grey if you have a recommended service schedule in general for our YZ450's? It seems you are definitely, in my opinion,  the most qualified guy to get direction on servicing Yamahas.  :) Thanks again!
  • joaquin1296
Posted December 01, 2013 - 11:28 PM
I have a question, is it possible to change the timing chain without opening the whole motor? I mean just the top end and ignition. Or you have to open the crankcase in half.
Posted December 02, 2013 - 07:21 AM
Yes.  Takes about an hour.
http://www.thumperta...f/#entry2520291
Posted December 02, 2013 - 08:45 AM
There isn't one.  It depends a lot on how you ride.  If you're up in the rev range all the time, they'll age faster than if you aren't.  Change them with each piston change at least, I would think.
  • roysicotte
Posted January 07, 2014 - 11:49 AM
changing the timing chain is super simple. take the top or your motor off to get to your cams. once you have your cams available you'll need to take the chain tensioner off along with your stator cover. then you pull your flywheel and take your stator off so you can get to the sprocket on the crank which is behind your flywheel and stator. that way you don't need to crack the motor. I just changed mine with the motor in the bike. refer to your manual for setting your timing.  this whole process on takes about 30 mins   very simple
  • etuke
Posted January 07, 2014 - 01:58 PM
so you don't have to remove the cams to do it?The 426 I had the cams had to come out to get the chain off the gear,even with the tensioner out of the cylinder it still wouldn't come off.
Posted January 07, 2014 - 02:11 PM
Not certain on the 2010+ models, but on all previous YZF's the cams must be removed.
