Time to split the cases on the ole wr400. Worthwhile upgrade recommendations needed.
6 replies to this topic
  • TurboDon
Posted November 27, 2013 - 08:47 PM
Well I'm pretty certain the rod & rodbearing finally exceeded their wear limit last weekend on my 99 WR 400.
The bike has a lot of hours/ miles on it. I want to freshen it up, make some good upgrades and get it ready for another decade or so of abuse.
As it sits the bike's current mods engine wise are : grey wire, yz timed, dr.d pipe, and airbox mods, and that's basically it.
The power on this bike has always been ok and it has been a solid runner. starts first kick unchoked stone cold and will go right to idle.
So basically I'm wondering what upgrades are recommended to be done while I have this thing torn down.
Here's what I had in mind.
have a new 426 rod pressed on the crank.
bore cylinder to 95mm.
13.5:1 weisco 426cc piston.
freshen up the head, most likely do some porting or at least port clean up (myself).
was thinking of upgrading the carb to something off a newer 426 or 450 (thoughts on this?)
should I change any bearings out?
should the clutch be upgraded for the increased power?
any other tips/ tricks/ suggestions?
Thanks.
-Donald
  • TurboDon
Posted November 29, 2013 - 07:02 PM
Everyone out riding for the weekend or what?
  • GuyGraham
Posted November 30, 2013 - 01:51 AM
Personally, I'd not invest the money and time in it and I'd get a later model for the better handling
Even if you replace every bearing and worn out part you are still gonna have a 15 year old bike with handling of a bike from the nineties
the al frame bikes were a good step forward in term of hanlding, over the steel framed 400/426/450 bikes
If you really do want to keep then replace rod, main bearings, any of the gears with pitting on the faces of the teeth, piston, rings & valve seals.
Sorry can't advise on the specifics, as I'm not that familiar with the 400/426 variants
  • TurboDon
Posted November 30, 2013 - 10:32 PM
Ya I want to keep it for sure.
The 6 hundred dollars or so for an overhaul is a small price to pay compared to scrapping it and buying a new bike.
Being as its plated in California makes it a pretty desirable.
I'm a pretty experienced rider and am not ashamed to say I've been passed hard by older vets on XR400s out on the trails.
A newer bike isn't going to make me get from point A to B any faster..... That electric start would sure be nice tho!
Thanks!
  • senorblondie
Posted November 30, 2013 - 10:38 PM
I actually have had 2 1999 wr400s. I love them. I still have one.
Have you heard of filing down the throttle stop?
  • TurboDon
Posted December 01, 2013 - 10:17 AM
Yeah I've heard of that one, For some reason when I checked mine out it seemed as though the slide opened to it's full potential without any modifications.
When I do this overhaul I have been contemplating putting on a newer carb off a YZ anyhow.
Edited by TurboDon, December 01, 2013 - 10:23 AM.
  • Tanis
Posted December 01, 2013 - 09:07 PM
Good to change the rod, iv seen a heap of wr 426 end up getting scraped after the rod failed, iv got one and they keep coming up on eBay in aus!
