Throttle Stop
16 replies to this topic
  • bobpara
Posted November 25, 2013 - 08:18 AM
I have a 2006 WR 450
I have looked for the throttle stop mod (the black plastic thing on the side of the carb and the top screw)
....I don't see it !.....I look at the mechanism and it seems like there is not stop screw fouling things up
I am going by a link for a 2007 WR.....did they switch to FI in o7 and my '06 has a carb?
I also don't see the AIS system at all....perhaps prev owner had already dumped it or it never had one
Can anyone shed any light on what mode SHOULD apply to my 06 WR450???
  • 080
Posted November 25, 2013 - 08:40 AM
AIS pic
http://www.thumperta...ht=AIS tutorial
Throttle
http://www.thumperfaq.com/throttle.htm
Hope this helps.
  • bobpara
Posted November 25, 2013 - 12:15 PM
Can I ask a dumb question? After looking at the throttle stop mod, how does that make the throttle open WIDER? It looks like a glorified idle screw that would set the position of the slide in the bore = idle.....how does an adjustment screw like this affect the WOT position of the slide???.....Confused
  • DrFeelGood
Posted November 25, 2013 - 12:19 PM
It's physically stops the throttle from opening up all the way.  It's not stopping the slider, per say, it's stopping the external cam business that the throttle cables are attached to.
  • DrFeelGood
Posted November 25, 2013 - 12:25 PM
Is the 06 a steel frame?
I know I have to remove the subframe, shock and carb to get my stop screw out.  It's an 08 alum frame though.
Edited by DrFeelGood, November 25, 2013 - 12:26 PM.
  • bobpara
Posted November 25, 2013 - 12:30 PM
I see a guy out on Craigs selling a bike identical to mine, an '06 WR 450
He advertises having done the throttle stop mod and having installed a 'Full throttle twist kit'
Any idea what that is?......Is he talking about an 1/8 turn throttle or something?
  • bobpara
Posted November 25, 2013 - 12:34 PM
OK, I believe you.
I was in there last summer, took a look, and I didn't see how it would effect the WOT position
I obviously missed something...
  • bobpara
Posted November 25, 2013 - 12:39 PM
It is an 06 and it has an aluminum sub frame but a steel mainframe.....i'm 98% sure.
Pain in the boules getting to the carb
But I was able to pop off the little side cover and take a peek at the stop screw w/o removing the whole carb assy.
Damned if I can see how that stop screw effects WOT though......
  • Krannie McKranface
Posted November 25, 2013 - 01:43 PM
Many WR's are modded at the dealer back then.
If you get WOT, then you are already good.
Posted November 25, 2013 - 01:44 PM
Are you sure you are looking at the throttle stop, and not the apump linkage?
  • The Hedgehog
Posted November 25, 2013 - 03:22 PM
The throttle stop mod is for real. And yes, it makes a huge difference.
  • vlxjim
Posted November 25, 2013 - 04:18 PM
If the mod was already done on yours there is still a screw there its just shorter and wont stop it from going wide open.
  • bobpara
Posted November 26, 2013 - 05:48 AM
I suppose the bottom line is the physical length of that screw, right?
I copied the article down....I think the length of the screw (from under the heat to the end) should be 0.790"
If i'm real lucky I can get in there again with a vernier caliper and measure its length
If I'm even luckier it will already be the correct length !!
Is there anything else I need to know or is it just a physical length of the screw issue?
Posted November 26, 2013 - 06:51 AM
Dude, just turn the throttle; if it feels like normal throw, you are done.
  • Kennoy
Posted January 04, 2014 - 08:11 PM
Someone please post a pic or link to video of the location of the throttle stop screw. Part number of YZ replacement screw would helpful too. Thanks
Posted January 05, 2014 - 08:02 AM
search function
  • The Hedgehog
Posted January 06, 2014 - 07:01 PM
Not to be a smart Alec, but there are probably about a dozen pics and solutions floating around on this site. Some posted part numbers and some posted specs on how to mill it down. They both work.
If that is all you need, I would just cut it down.
