One light Clutch? Looks good.....
41 replies to this topic
  • Navaho6
Posted January 20, 2014 - 11:40 AM
#41
That's awesome!  Looking forward to getting mine set up.
What specifically did you do with the excess cable length? I have a shorter cable coming in this week but others might want to stick with oem length like you did.
  • Navaho6
Posted February 02, 2014 - 01:13 PM
#42
Finally got my custom cable in and hooked up the Moose Easy Pull clutch system.  Cranked her up.
The good news is it that it does make the pull a lot easier.  The bad news is that it makes the pull a lot longer too.  I adjusted it until all the slack was out, then tightened it some more(past the point where the lever was snug).  Never could get to a point where the clutch would fully disengaged to quite extent it would with a standard set up.  It required the lever to be all the way in, toughing the bars.  I didn't like the longer pull so I put it back to oem cable and ASV lever.  I can live with that for 95% of the riding I do.
Oh, the 5.25" shorter cable was the perfect length for use with the Moose.  I've got one for sale real cheap... and a Moose easy pull clutch system too.
