These forks!?! 2014 YZ450...
Yamaha YZ450F 2014
87 replies to this topic
  • YZ450F2014
Posted May 30, 2014 - 05:24 AM
#81
Hi,
Is it possible to remove 2-3 chims from the compression basevalve and add it to the rebound stack? Is it the same size?
Edited by YZ450F2014, May 30, 2014 - 05:25 AM.
Posted May 30, 2014 - 06:39 AM
#82
That depends on which shims.  Both stacks have the same inside diameter, but the face shims are a much different size.  Not all of the harshness of the compression stroke is related to the compression valve, anyway, as the mid valve comes into play as well.   It would be pretty unusual to end up doing what you suggest, because the rebound face shims are 20mm, while the base valve is 32mm.  There's only one 20 in the base valve, and it's way up the stack, so you'd not likely remove that one anyway.
  • crf917rider
Posted May 30, 2014 - 08:22 AM
#83
Grey im changing my springs (stiffer) if u can believe that ,what would u recommend for fork oil height and brand
A simple dont care to answer would have been nice ....
  • swaldrop
Posted May 30, 2014 - 08:54 AM
#84
Yeah, what a jerk. How dare he occupy his time with something other than immediately responding to every single post made on this website.
  • jnabuurs
Posted May 30, 2014 - 09:28 AM
#85
I can give you the solution to get it right. To make the bike work you have to make changes front and rear.
  • crf917rider
Posted May 30, 2014 - 10:51 AM
#86
That was posted a month ago no big deal i just see post after post with almost spot on response time sorry for the rant ive already got it set up thanks
Edited by crf917rider, May 30, 2014 - 10:51 AM.
Posted May 30, 2014 - 12:24 PM
#87
May 22nd was 8 days ago.
  • crf917rider
Posted May 30, 2014 - 03:05 PM
#88
Lol
