Who else has had major engine carnage?
9 replies to this topic
  • jojo1224
Posted November 07, 2013 - 09:15 PM
Well today the rod broke in my yz426f in 5th gear @ about 10k rpm, I was buzzing along at WOT for a short period of time then it went bang, crunch then quiet so I pulled over to find no compression. From what I found after pulling the head and jug was the Versah rod broke right below the small end and looks like it has been slowly cracking for a while now. It took out the valves, piston, cylinder, crank and cases. It had about 25hrs on a complete top and bottom rebuild after having my +2mm big bore (444cc) cylinder crack after 10hrs and filling the cases with coolant.
What major failures have you had or am I the only one with such bad luck?
Edited by jojo1224, November 07, 2013 - 09:17 PM.
  • SWIGIN
Posted November 09, 2013 - 08:27 AM
I haven't yet but my buddy was cracking piston tops and just kept replacing them without digging farther. Well, the rod finally broke at the small end which sent the counter balance flying out of the front of the cases...total loss.
  • peaceofwork
Posted November 15, 2013 - 08:13 PM
I have read about more than a couple of 444 motors popping. one theory is that the cylinder becomes too thin and billows allowing the piston to rock in the bore and side load and self destruct.
my kid was running a 450/533 ktm he pulled it apart to have a look and good thing he did, so now its going back together 2mm less with a steel sleve
more preshure and thiner cylinder wall,s may not be the best combination
  • Tanis
Posted November 18, 2013 - 04:22 AM
You mean like that, small end failed took out the case and the bore but the head is still good its a wr 426
  • yellow ketchup
Posted November 18, 2013 - 04:38 AM
I had an 01 426 snap the head off the exhaust valve which took out the whole top end. Then an 06 450 break the big end of the rod which took out everything except the head...I'm lovin my new Suzuki!
  • thestuz
Posted November 19, 2013 - 03:39 AM
let us know how that gear box holds up!
  • yellow ketchup
Posted November 19, 2013 - 05:02 AM
I've ridden suzukis since the early 90s, save the two yzf's, and never had a gear box problem. ..maintenance is key
  • Boston Mangler
Posted December 17, 2013 - 01:11 AM
I recently blew a head gasket out in the desert riding wide open most of the day.
06 YZ450F that i picked up with only 20 hours on it..
Wasn't sure exactly what was wrong, so limped it about 4 miles back to camped..
Overheated the shit out of it and did the following:
-Piston chunks came off
-Destroyed Cylinder
-Got exhaust cam DARK BLUE from heat
-Warped head
Initially thought it wasnt that bad, further i am digging into it, the more i am thinking its damn near total loss!
Argg
  • alfie
Posted December 20, 2013 - 02:27 AM
Ive had four wr's the 400, 426 and the 450  i have never really had any major motor problems. Other than normal wear and tear and a bad hot cam for the 426 trying to the auto decomp mod. I have also seen the motors let go and most of this was down to bad maintenance or bad luck.
  • Tanis
Posted December 20, 2013 - 03:05 AM
Bad luck? = bad manufacture?
  • Hot  30 replies
  • Hot  47 replies
  • Hot  38 replies
  • 5 replies
  • 0 replies
