Engine relocation kit yz450
12 replies to this topic
  • Mtrain730
Posted November 07, 2013 - 05:02 PM
I know this has Ben touched on before but I have my bike striped down for the winter and want too hear some people view. Is it a valid upgrade or is moving the engine up a couple millimeters Just spliting hairs that the average joe will never notice it. I have read a couple old threads on this but it seemed be just talking crap back and fourth with no actual useful info or facts too back up there position. I do like my 2012 yz and plan too keep it a while. Thanks guys.
  • rickallen124
Posted November 07, 2013 - 06:18 PM
It certainly makes the front end more planted. If all I rode was loamy/sand tracks I wouldn't install it, but for hard pack/intermediate soil it makes a big difference.
  • Mtrain730
Posted November 07, 2013 - 06:36 PM
Thanks for the replay. I live in ny. Just started racing. Starts out kind of normal loose dirt i would say soft too med starts too get a little packed down by the end of the day. I am willing too admit I'm sure my riding skill is 99 percent too blame( not completely new too dirt bikes just racing them)but cornering is where I need help. Seem too push a little. I gonna experiment with a different bend of handle bars and switch out the mx51 front for some thing else wondering if the relocation kit would help a little too. Thanks for the input.
  • kurtcrf450
Posted November 07, 2013 - 06:50 PM
Make sure your race sags correct and raise the forks to 5 or 8 mm(can't remember which) if you do. Made a huge difference for me and gave me a ton of confidence in the front end. If you can afford to replace tires every couple of ride the mx31 offers excellent traction in my experience but knobs break of real fast
  • Mtrain730
Posted November 07, 2013 - 07:10 PM
Thanks I have about 100mm race sag have experimented with with the forks I raised them 3 mm and 5mm. The mx31 was the tire I was gonna try next.
  • rickallen124
Posted November 07, 2013 - 09:52 PM
the mx31 is certainly better than the mx51, but it will tear knobs off if you run it on hardpack. I've run the 31/51 combo for a while and it  works well. I just put a bridgestone 203 on the front as I've heard really good things about them in mixed terrain.
  • joaquin1296
Posted November 08, 2013 - 06:50 AM
For hardpack. I would recommend the pirrelis mid/hard 554. I discovered this tyres one momth ago. IMO much better than MX51 in same conditions.
Speaking of the KIT no experience. I ride with the forks flush with the clamp (Manual amd MXA recommendations). And I always try to follow gary semics tips. It is what has really helped with cornering.
  • Mtrain730
Posted November 08, 2013 - 01:55 PM
The track I go too only gets run on about 1 day a month so there actually grass on it for the first couple races. I personally would classify it as soft and maybe medium by the end of the day with some hard pack areas. If I can trade some tire wear for a more grabby front tire I would gladly do that especially since I am not able too ride nearly as much as some people so the tire would last a while for me. I'll keep experimenting when money permits thanks guys.
  • zeuszuki
Posted November 08, 2013 - 02:14 PM
Agree with this, i used my '11 for woods and MX so no relocation for me . My tip - front tyre choice is critical on this bike.
  • Mtrain730
Posted November 08, 2013 - 02:50 PM
Am I correct too think if the bike pushes a little bit or doesn't corner sharp enough that going too a softer terrain tire is probly the way too go. I should add I'm only 165 so I'm probly on the light side for the suspension and some one has pointed out too me that might be contributing too the bike pushing and standing up in corners because the forks don't ride low enough in the stroke when entering the corner how ever I don't have the money too send my suspension out. So I'm trying too address the issues( even if there just in my head). Buy going at some other way. Bike is bone stock exect for fly wheel weight and a set of windam bend bars that I'm gonna try out.
Posted November 08, 2013 - 09:55 PM
No.  "Hard" and "soft" as used to describe dirt bike tires are terms that refer to the type of soil the bike is to be run in, not to the rubber of the tire.  Tires for soft surfaces will have taller and thinner knobs spaced farther apart to fork into the soil.  "Hard" tires have fatter blocks closer together, often with "cups" dug into the outermost rows of knobs, and the knobs will be shorter so as not to roll and squirm under hard cornering on really hard stuff.
  • rotax800
Posted November 09, 2013 - 06:20 PM
As for the relocation kit, it works. But, since you said you are 165 lbs, money would be better spent just respringing the bike for your weight. I think it comes with a 5.8nm in rear and  48 fronts. I dont think you will get proper free sag after setting up race sag. Factory connection can get you where you need to be for a couple hundred which is a little more than the relocate kit, but will be way better for you. I have an 11 with all the goodies and nothing helped more than the proper springs.
Having said that i bought a 2014 and its night and day dif. The smoother motor along with all the other changes makes the bike way more predictable and confidence instilling. needless to say, the 11 is for sale with 60 hours on it
Hope this helps
  • Mtrain730
Posted November 09, 2013 - 08:15 PM
Factory connection quoted meat around700 after shipping. That's a little more than I can spend just for the suspension right know. They actually have my forks at the moment and are just changing the oil and seals and replacing a fork cap I stripped and that's gonna be about 300. Thanks for the info though. You might laugh at this but I'm just gonna try and gain 10 pounds over the winter. Lol. Maybe it will help maybe it won't.
  • Hot  28 replies
  • 10 replies
